Certbot Verification Issue (Challenge failed for domain)
I'm installing certificate using:
sudo certbot --nginx -d certbot.ddnsking.com
http-01 challenge for certbot.ddnsking.com
Challenge failed for domain certbot.ddnsking.com
I guess the problem is with /.well-known/acme-challenge/14p-Zi4UV83zsePM5dPRGlikyo7ZyXjeViefLDatdlg availability (cause it's not available)...
The log file is uploaded to privnote:
https://privnote.com/G4Yy9O4j#0vmDaM6eH
Please advise if any possible solution is available. Thank you.
Hi @CEBEP
looks like your vHost configuration is buggy. Checking your domain a wrong certificate is used - https://check-your-website.server-daten.de/?q=certbot.ddnsking.com
CN=desarrollandoamerica.org
	26.09.2019
	25.12.2019
expires in 14 days
desarrollandoamerica.org, www.desarrollandoamerica.org - 2 entries
What says
nginx -T
Every combination of port and domain name must be unique. Or a vHost definition is wrong, so the vHost isn't used.
https://privnote.com/DJ9yDYNT#8EKd0IJwb
There you see your problem.
Looks buggy - no listen, not the list of domains you use in your command -> Certbot can’t find the correct vHost -> one of the other vHosts is used.
PS: Looks like you have created that vHost manual.
Dear Juergen, thank you for your help and time. I have no idea how I managed to remove virtual host from nginx config. All works smoothly. Thank you once again.
