Good morning, I'm having problems renewing my certificate. I always managed to renew, but now I'm having problems.
Validations made
DNS OK
Firewall disable
http-01 challenge for devmaps.informs.conder.ba.gov.br
Using the webroot path /var/www/letsencrypt for all unmatched domains.
Challenge failed for domain domin.ba.gov.br
http-01 challenge for domain.ba.gov.br
Hi @andradeee and welcome to the LE community forum
My domain is: gitlab.conder.ba.gov.br
I ran this command: certbot certonly --webroot --webroot-path=/var/www/letsencrypt -d gitlab.conder.ba.gov.br
My web server is (include version): gitlab with nginx
The operating system: Centos7
The version of my client is: certbot 1.11.0
http://domain.ba.gov.br/.well-known/acme-challenge/w3PYUvXNZB Doesn't match the any of the stated domains: gitlab.conder.ba.gov.br devmaps.informs.conder.ba.gov.br
In the case that you simply obscured it and they are one and the same, the error message tells you exactly why it fails.
You must have a working HTTP site before you can secure it (via HTTP authentication).
Well, not well enough for Let's Encrypt. Looks like DNS failure with CAA record. You do not need a CAA record but DNS cannot SERVFAIL trying to find one. Try connection with
