"Timeout during connect" on renewal
My domain is: mirror.anarc.at
   Domain: mirror.anarc.at
   Type:   connection
   Detail: Fetching
   http://mirror.anarc.at/.well-known/acme-challenge/5_CpOCx38guwL_I9Gd1x5VaNopxi_rCUwobYJehbsFg:
I have also tried:
root@marcos:/etc# certbot certonly -d mirror.anarc.at --webroot  -w /var/www/mirror/
Renewing an existing certificate for mirror.anarc.at
http-01 challenge for mirror.anarc.at
Using the webroot path /var/www/mirror for all unmatched domains.
Challenge failed for domain mirror.anarc.at
   Type:   connection
   Detail: Fetching
   http://mirror.anarc.at/.well-known/acme-challenge/B1k-K3ozfrJ5hQx7d5lLhLzUD3C8w1jNxrnRGZIxSLY:
And I can reproduce the issue on Let's Debug (although debugging shows the webserver is reachable, see Let's Debug), but nowhere else: I have tried from people.debian.org and other machines and they can all reach my server correctly. I am not firewalling port 80 or 443, although I am redirecting the former to the latter, which never caused problems in the past.
My web server is (include version): 2.4.52-1~deb11u2
The operating system my web server runs on is (include version): Debian 11 "bullseye"
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.12.0
I should also point out that I've been tracking my /etc directory in git for a while, with daily autocommit. Since around November, I started noticing an accumulation of CSRs in /etc/letsencrypt/csr, where I now have a whopping 1638 entries. Typically, I'd get new CSRs added there when new certificates are renewed, but because renewals have started breaking at some point in the past, I'm now adding dozens of CSRs a day in there. It seems that, around March 3rd, the Let's Encrypt servers have started having trouble reaching my server and I cannot clearly explain why this is happening anymore.
I've been using Let's Encrypt since at least 2017, and this is the first time I need to ask for help around a problem like this. Typically, the configuration issues are on my end: some expired DNS entry or misconfigured virtual host. But this is different: nothing changed on my end, and things seem to be working from other point of views on the network. I also tried to check the challenge by using --debug-challenges and curling the URL to see if the challenge is really available, and it is (with curl -L).
Is there something obvious I'm missing here? I looked at other issues like HTTP challenge fails: Timeout during connect, DNS problem - #5 by JuergenAuer and I don't seem to find anything that matches my experience there.
Thanks for any input.
Hi @anarcat,
Is it possible that your hosting provider or ISP is blocking certain address ranges?
It does seem that most parts of the Internet can reach your server, but the Let's Encrypt validation consistently can't, which might suggest a hidden firewall rule or something.
Hi @schoen!
It's possible, I guess i'll escalate with them now, but this is highly unusual: typically they don't block anything like this. I'll ask.
Could someone at LE get me a traceroute to see where the traffic gets drop? Is there a looking glass or something?
Also: I guess that a DNS-01 challenge could workaround such a problem, no?
It's rare, you would usually have to attract the attention of a busy LE staffer. :slight_smile: The LE staffer might first ask you to check with your ISP, as you're trying.
That could be very useful in some cases, but it doesn't exist now and I don't know if there would be concerns about attack surface or resources in hosting it on the same infrastructure as the actual validation.
Yes, it's pretty rare for DNS servers to refuse queries from anywhere.
Oh dear, my ISP seems to have fallen down the trap of "our call is important to us" and redirect me to a "community support forum", where I posted this link:
https://community.teksavvy.com/discussion/1498/timeouts-connecting-inbound-from-lets-encrypt/p1?new=1
What a nightmare... I suspect this will get about zero traction and will start looking at alternatives (ISP, and DNS-01 of course).
i actually got on the phone (remember those?) with them and they claim to not be blocking any port or any traffic on their side, so this would be some bizarre routing issue of some sort, which brings me back to needing some sort of traceroute from Let's encrypt to diagnose this further. Sigh.
When I looked yesterday, Let's Encrypt was able to connect to other hosts in your /24 (e.g. to 206.248.172.208).
Based on that, it does seem most likely to me that you have some firewall rule on your machine which is causing this:
  • Although your ISP could be blocking port 80 for your specific IP, I don't know why they would single you out. Unless there is some plan-based differentiation?
  • Asking for a traceroute from Let's Encrypt probably won't be too helpful because AFAIU routing tables do not have anything smaller than /24.
Is this Debian server behind a NAT, or plugged directly in to your internet connection? Have you tried rebooting your router/modem, if any?
It's behind NAT with port forwarding for that host, and I must admit I haven't tried rebooting the router, this is the nex step.
well this is embarrasing, rebooting the router actually fixed this issue.
my hunch was this was IPv6 related, and I think it was spot on in the end. this IPv6 setup has a tendency of falling apart upstream after a while. reconnecting the IPv6 interface (or rebooting) typically fixes it, so my guess is that Let's Encrypt was trying to connect over IPv6 and failing to fallback.
is that a known issue? nothing confirmed on my end of course, just a hunch. in fact, i still can't quite reliably renew the domains... some did go through, but some still get timeouts...
sorry for the noise, and thanks for the stellar support.
Hooray for shoddy CPE!
I don't think IPv6 was involved here. If we look at the authorization details (https://acme-staging-v02.api.letsencrypt.org/get/authz-v3/1982674078), we can see that Let's Encrypt only resolved an IPv4 address for your domain, and failed to connect on that address.
We've also previously seen "helpful" router features which throttle traffic as a sort of anti-DoS feature. Let's Encrypt challenge requests tend to arrive all at once, which can trigger a blocking response.
The thing is: that's not supposed to be some shoddy random SOHO router. This is the turris omnia, with a real Linux (OpenWRT) under it. It should be able to handle, you know, port forwarding. :stuck_out_tongue:
That is really, truly bizarre then. I really don't understand what the heck happened here...
If this was a situation where the site was just down, I'd get it, but the traffic was blanking out only for let's encrypt! I didn't find another site that had those timeout issues. And even now that most (but not all!) of my certs have renewed, there's still one more left that's stumbling upon itself:
   Domain: analytics.anarc.at
   Type:   connection
   Detail: During secondary validation: Fetching
   http://analytics.anarc.at/.well-known/acme-challenge/VXVDzedJ_MTPxKKaA8K-c7u8coBdlIOkItkROTqLeXE:
Notice how it's failing in the secondary validation now. Also note that all those DNS records are basically CNAMEs to the same host right now, so if they were able to route for some, it should route for all, no?
That could actually be something the Turris does. And lo and behold, there's this "Dynamic firewall" thing that I seem to have naively enabled in there. Disabling it seems to make that final cert just go through fine.
Sigh, thanks, and sorry again for the noise, I feel quite silly.
Interesting! One of the Let's Encrypt validation servers is listed on today's Turris greylist as an "http" attacker.
oh wow, that sounds like something we (who?) should fix.
I reported the problem upstream here:
