Hello, I run sudo certbot renew and I get:
   Domain: tantramassagewarsaw.com
   Type:   connection
   Detail: Fetching
   http://tantramassagewarsaw.com/.well-known/acme-challenge/0JPv8i_1XO6y32rpQrbH4EnAg0LwteuRUSqL_feIR2s:
   Domain: www.tantramassagewarsaw.com
   Type:   connection
   Detail: Fetching
   http://www.tantramassagewarsaw.com/.well-known/acme-challenge/CnKEWlZQMUfI_Il-kQ29D-WExWSq-E4TMFLaU2Gufnw:
The certs renewal have been working fine, but now this error appeared.
ufw status
Inactive
No other firewall installed.
Nginx vhost is:
        listen 80;
        server_name tantramassagewarsaw.com www.tantramassagewarsaw.com;
        root /var/www/masaztantrycznywarszawa.pl/masaztantrycznywarszawa.pl;
        return 301 https://tantramassagewarsaw.com$request_uri;
        listen 443 ssl;
        server_name tantramassagewarsaw.com;
        ssl_dhparam /etc/nginx/dhparam.pem;
        ssl_session_cache shared:SSL:10m;
        ssl_session_timeout 10m;
        ssl_certificate "/etc/letsencrypt/live/tantramassagewarsaw.com/fullchain.pem";
        ssl_certificate_key "/etc/letsencrypt/live/tantramassagewarsaw.com/privkey.pem";
        ssl_protocols TLSv1.2;
        ssl_ciphers "EECDH+ECDSA+AESGCM EECDH+aRSA+AESGCM EECDH+ECDSA+SHA384 EECDH+ECDSA+SHA256 EECDH+aRSA+SHA384 EECDH+aRSA+SHA256 EECDH+aRSA+RC4 EECDH EDH+aRSA RC4 !aNULL !eNULL !LOW !3DES !MD5 !EXP !PSK !SRP !DSS !RC4";
        return 301 https://www.tantramassagewarsaw.com$request_uri;
        listen 443 ssl;
        server_name www.tantramassagewarsaw.com;
        index index.php;
        add_header Strict-Transport-Security "max-age=31536000; includeSubdomains;";
        add_header Strict-Transport-Security "max-age=31536000;";
        charset utf-8;
        location ~ \.php$ {
                fastcgi_split_path_info ^(.+\.php)(/.+)$;
                fastcgi_pass unix:/run/php/php-fpm.sock;
                fastcgi_index index.php;
                fastcgi_param SERVER_NAME $host;
                include fastcgi_params;
        location ~* \.(jpg|jpeg|png|gif|ico|css|js|woff|woff2)$ {
                expires 365d;
Other certificates in the same machine seemt o have well updated yesterday night automatically. Many of them have: (VALID: 79 days). But this one only doesn't seem to want to be renewed.
Any idea what else I can check?
Hi @seekman
your configuration looks buggy, see https://check-your-website.server-daten.de/?q=tantramassagewarsaw.com
Host Type IP-Address is auth. ∑ Queries ∑ Timeout
tantramassagewarsaw.com A 54.37.137.250 Wrocław/Lower Silesia/Poland (PL) - OVH SAS Hostname: vps-81c304cb.vps.ovh.net yes 1 0
A 80.211.183.70 Arezzo/Tuscany/Italy (IT) - Aruba S.p.A. No Hostname found yes 1 0
AAAA yes
www.tantramassagewarsaw.com A 54.37.137.250 Wrocław/Lower Silesia/Poland (PL) - OVH SAS Hostname: vps-81c304cb.vps.ovh.net yes 1 0
AAAA yes
You have two different ipv4, different places.
The 54.* works, the 80.* has only timeouts, see the #url-checks part.
Looks like the 80.* is old / expired, remove that.
Thank you. It looks like I forgot to delete the old record.
I'll wait for dns update and retry,
You might try using letsdebug.net as a quick way to test. If you need more comprehensive analysis, you can use @JuergenAuer's own check-your-website.server-daten.de (which he has already run for you in this case).
Update: Unfortunately, letsdebug.net appears to currently be stuck on the active incident involving the Testflume CT Logs.
https://letsencrypt.status.io/
thank you all. It worked fine after fixing the dns records
