pacolola.net
certbot certonly -d pacolola.net --webroot --webroot-path /var/www/pacolola
Failed authorization procedure. pacolola.net (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://pacolola.net/.well-known/acme-challenge/A6N4Hm23Lwd1QwRw9DCqpFuiZ0dGb5qc3xf7cYAEi7s: Timeout during connect (likely firewall problem)
Apache/2.4.38 (Debian)
Armbian 21.02.3 Buster with Linux 5.10.21-imx6
Yes.
No.
0.31.0
What I have done so far is to
  • Uncomment all rows in the site config found in etc/apache2/sites-available/pacolola.conf which relates to redirection to https (restart server afterwards)
  • Made sure it's possible to access https://pacolola.net/.well-known/acme-challenge/test
  • Checking the access settings on my home router which is set to medium, blocking NETBIOS and DNS
  • Attempted to disable the server firewall temporarily ufw disabled while renewing the certificate. Firewall is back on again.
  • Checked the status over at https://check-your-website.server-daten.de/?q=pacolola.net which yes, says that the connection over port 80 gives the error status -14, but I don't know what further actions I can take now.
I have a nextcloud instance running on a subdomain if that is of any interest.
It seems like you have assigned IP address to this host, but the port for 80 is not open... It's actually not at all necessary for you to close port 80 (as it's a normal communication port). Can you try to allow port 80 access now and see if the host respond?
P.S. sorry I'm on mobile, so my tools are limited.
Welcome to the Let's Encrypt Community :slightly_smiling_face:
I concur with @stevenzhu.
I had port 80 open according to /etc/apache2/ports.conf : Listen 80
And can't see anything blocking the port on the router. I'll have to look in other places where port 80 could be blocked.
sudo lsof -n -sTCP:LISTEN -i:80 returns:
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
apache2 1726 root 4u IPv6 1602318 0t0 TCP *:http (LISTEN)
apache2 2044 www-data 4u IPv6 1602318 0t0 TCP *:http (LISTEN)
apache2 2045 www-data 4u IPv6 1602318 0t0 TCP *:http (LISTEN)
Thank you for the response.
If i parsed the message correctly, you actually only listened on IPv6... (Type IPv6)
Can you double check on your apache configuration?
AND, your IPv4 port 80 is still filtered
Snipaste_2021-04-05_17-22-17
P.S. If you are worrying about degrade attack, you can setup a blanket redirection that sent all incoming traffic through 301 redirection to https :slight_smile:
Port 80 should be open as per ufw status:
Status: active
To                         Action      From
22/tcp                     ALLOW       Anywhere
80/tcp                     ALLOW       Anywhere
443/tcp                    ALLOW       Anywhere
873/tcp                    ALLOW       Anywhere
WWW Secure                 ALLOW       Anywhere
WWW Full                   ALLOW       Anywhere
80                         ALLOW       Anywhere
22/tcp (v6)                ALLOW       Anywhere (v6)
80/tcp (v6)                ALLOW       Anywhere (v6)
443/tcp (v6)               ALLOW       Anywhere (v6)
873/tcp (v6)               ALLOW       Anywhere (v6)
WWW Secure (v6)            ALLOW       Anywhere (v6)
WWW Full (v6)              ALLOW       Anywhere (v6)
80 (v6)                    ALLOW       Anywhere (v6)
I retested the port, and it's still closed.
If you are using residential internet or something, can you also check with your ISP to see if they block port 80 by default?
Thank you
Hi @droid001
checking that result your port 443 / https works. So the firewall / router configuration of port 443 is ok -> check, if port 80 has the same settings.
May be your Apache configuration doesn't work, so it doesn't answer via ipv4.
What says
apachectl -S
Thanks for taking interest @JuergenAuer .
The firewall/router config is the same for port 80 as it is for 443.
I checked out what was coming out from apachectl -S and noticed that port :80 was serving the subdomain nextcloud.pacolola.net and not the main one. I changed virtual host file nextcloud.pacolola.net.conf to be more specific about what was served from port 80, <VirtualHost nextcloud.pacolola.net:80>.
After that I'm get the following:
VirtualHost configuration:
188.151.218.129:80     nextcloud.pacolola.net (/etc/apache2/sites-enabled/nextcloud.pacolola.net.conf:1)
*:4443                 127.0.0.1 (/etc/apache2/sites-enabled/ncp.conf:2)
*:80                   pacolola.net (/etc/apache2/sites-enabled/pacolola.conf:1)
*:443                  is a NameVirtualHost
         default server nextcloud.pacolola.net (/etc/apache2/sites-enabled/nextcloud.pacolola.net-le-ssl.conf:2)
         port 443 namevhost nextcloud.pacolola.net (/etc/apache2/sites-enabled/nextcloud.pacolola.net-le-ssl.conf:2)
                 alias www.nextcloud.pacolola.net
         port 443 namevhost nextcloud.pacolola.net (/etc/apache2/sites-enabled/nextcloud.pacolola.net.conf:10)
         port 443 namevhost pacolola.net (/etc/apache2/sites-enabled/pacolola-le-ssl.conf:2)
                 alias www.pacolola.net
         port 443 namevhost 127.0.0.1 (/etc/apache2/sites-enabled/pacolola.conf:15)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
I finally got a certificate running with the following command: certbot -d pacolola.net --manual --preferred-challenges dns certonly.
I have a Dynamic DNS set on my router as the ISP doesn't provide a a static one and am using NO-IP as the name registrar and DNS provider. Tried using acme-dns-certbot but it wasn't picking up the TXT record set for _acme-challenge.pacolola.net. Luckily certbot did. :grinning:
