My domain is: torranceairductcleaning.com
I ran this command: wo site update torranceairductcleaning.com -le
and wo site update torranceairductcleaning.com -le --force
2020-12-23 12:42:48,068 (INFO) wo : Issuing SSL cert with acme.sh
2020-12-23 12:42:48,069 (DEBUG) wo.core.logging : Running command: /etc/letsencrypt/acme.sh --config-home '/etc/letsencrypt/config' --issue -d 'torranceairductcleaning.com' -d 'www.torranceairductcleaning.com' -w /var/www/html -k "ec-384" -f
2020-12-23 12:43:02,626 (DEBUG) wo.core.logging : Command Output: [Wed 23 Dec 2020 12:42:48 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Wed 23 Dec 2020 12:42:48 PM UTC] Multi domain='DNS:torranceairductcleaning.com,DNS:www.torranceairductcleaning.com'
[Wed 23 Dec 2020 12:42:48 PM UTC] Getting domain auth token for each domain
[Wed 23 Dec 2020 12:42:49 PM UTC] Getting webroot for domain='torranceairductcleaning.com'
[Wed 23 Dec 2020 12:42:50 PM UTC] Getting webroot for domain='www.torranceairductcleaning.com'
[Wed 23 Dec 2020 12:42:50 PM UTC] Verifying: torranceairductcleaning.com
[Wed 23 Dec 2020 12:42:52 PM UTC] Pending
[Wed 23 Dec 2020 12:42:54 PM UTC] Pending
[Wed 23 Dec 2020 12:42:57 PM UTC] Pending
[Wed 23 Dec 2020 12:42:59 PM UTC] Pending
Command Error: [Wed 23 Dec 2020 12:43:01 PM UTC] torranceairductcleaning.com:Verify error:Fetching http://torranceairductcleaning.com/.well-known/acme-challenge/G8ZKPHZF7CsgkJwracK9eSg_Cnzd9CPGfrDMA6Gps-4: Timeout during connect (likely firewall problem)
[Wed 23 Dec 2020 12:43:01 PM UTC] Please add '--debug' or '--log' to check more details.
[Wed 23 Dec 2020 12:43:01 PM UTC] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
2020-12-23 12:43:02,627 (INFO) wo : Issuing SSL cert with acme.sh
2020-12-23 12:43:02,627 (ERROR) wo : Your domain is properly configured but acme.sh was unable to issue certificate.
You can find more informations in /var/log/wo/wordops.log
nginx/1.18.0 (WordOps Nginx-wo)
Ubuntu 20.4 64x
My hosting provider, if applicable, is: Vultr VPS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): WordOps
using acme.sh via WordOps
I had not restarted the server after adding the IP
But now I am rate limited. How long do I have to wait before trying again?
Command Error: [Wed 23 Dec 2020 01:29:10 PM UTC] Create new order error. Le_OrderFinalize not found. {
"type": "urn:ietf:params:acme:error:rateLimited",
"detail": "Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/",
"status": 429
For some reason it is trying to create the .well-known folder in the default server root, not the site root. It's pulling the wrong root. I am not running the acme.sh script myself, but through WordOps, which worked fine on the previous 3 servers, so I've no idea why this is different now.
2020-12-23 15:52:19,816 (DEBUG) wo.core.logging : Validation : Webroot mode
2020-12-23 15:52:19,817 (DEBUG) wo.core.logging : Changing ownership of /var/www/html/.well-known, Userid:33,Groupid:33
2020-12-23 15:52:19,817 (DEBUG) wo.core.logging : Changing permission of /var/www/html/.well-known, Perm:488
2020-12-23 15:52:19,817 (INFO) wo : Validation mode : Webroot challenge
2020-12-23 15:52:19,817 (INFO) wo : Issuing SSL cert with acme.sh
2020-12-23 15:52:19,817 (DEBUG) wo.core.logging : Running command: /etc/letsencrypt/acme.sh --config-home '/etc/letsencrypt/config' --issue -d 'torranceairductcleaning.com' -d 'www.torranceairductcleaning.com' -w /var/www/html -k "ec-384" -f
2020-12-23 15:52:24,907 (DEBUG) wo.core.logging : Command Output: [Wed 23 Dec 2020 03:52:20 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Wed 23 Dec 2020 03:52:20 PM UTC] Multi domain='DNS:torranceairductcleaning.com,DNS:www.torranceairductcleaning.com'
[Wed 23 Dec 2020 03:52:20 PM UTC] Getting domain auth token for each domain
[Wed 23 Dec 2020 03:52:21 PM UTC] Getting webroot for domain='torranceairductcleaning.com'
[Wed 23 Dec 2020 03:52:21 PM UTC] Getting webroot for domain='www.torranceairductcleaning.com'
[Wed 23 Dec 2020 03:52:21 PM UTC] Verifying: torranceairductcleaning.com
Command Error: [Wed 23 Dec 2020 03:52:24 PM UTC] torranceairductcleaning.com:Verify error:Invalid response from http://torranceairductcleaning.com/.well-known/acme-challenge/R9yICyftBYC7kcY_Kpj6oxVmh3S6caYru8-IKSffD7Q [207.246.85.153]:
[Wed 23 Dec 2020 03:52:24 PM UTC] Please add '--debug' or '--log' to check more details.
[Wed 23 Dec 2020 03:52:24 PM UTC] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
