www.elnuvolet.com
sudo certbot certonly --webroot -w /var/www/owncloud -d www.elnuvolet.com
also without www:
sudo certbot certonly --webroot -w /var/www/owncloud -d elnuvolet.com
http-01 challenge for www.elnuvolet.com
Using the webroot path /var/www/owncloud for all unmatched domains.
Waiting for verification…
Failed authorization procedure. www.elnuvolet.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.elnuvolet.com/.well-known/acme-challenge/FSng0hzXEGjgUxwk9BFsMB7yd8ofaNotXeIndfyJMkw: Timeout during connect (likely firewall problem)
Domain: www.elnuvolet.com
Type: connection
Detail: Fetching
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
apache2 -v
Server version: Apache/2.4.29 (Ubuntu)
Server built: 2020-03-13T12:26:16
cat /etc/os-release
NAME=“Linux Mint”
VERSION=“19.2 (Tina)”
ID=linuxmint
ID_LIKE=ubuntu
PRETTY_NAME=“Linux Mint 19.2”
VERSION_ID=“19.2”
VERSION_CODENAME=tina
UBUNTU_CODENAME=bionic
https://www.movistar.com
no
certbot --version
certbot 0.31.0
Additional info:
I cheked the url with my phone and i can load the page correctly. there are 3 vhosts:
the first one redirects to https, the secondone adds the www to the url and the third one serves the content.
Also cheked with “check-your-website.server-daten.de”
here
My router is a pfSense, on the NAT table there are two rules that redirect trafic to the internal server. There’s suricata running, stopping it doesn’t change the certbot result.
Also the pfSense updates de IP from the Dynamic DNS noip.com
Internal server firewall
sudo ufw status
Status: active
To Action From
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
22/tcp ALLOW 192.168.XX.XX
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
