Timeout during connect (likely firewall problem, but there is no specific error that it is)
What next I have to check and how?
https://crt.sh/?q=darzeliai.panevezys.lt
https://crt.sh/?q=www.darzeliai.panevezys.lt
$ sudo ufw status
status: inactive
sudo iptables -L -n
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
apachectl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:80 darzeliai.SSG5-Serial (/etc/apache2/sites-enabled/000-default.conf:1)
*:8080 darzeliai.SSG5-Serial (/etc/apache2/sites-enabled/000-default.conf:30)
*:443 darzeliai.SSG5-Serial (/etc/apache2/sites-enabled/000-default.conf:59)
sudo ss -tlnp | grep -E “(apache|httpd)”
LISTEN 0 128 :::8080 :::* users:((“apache2”,16747,6),(“apache2”,16700,6),(“apache2”,16686,6),(“apache2”,16683,6),(“apache2”,16652,6),(“apache2”,16651,6),(“apache2”,16645,6),(“apache2”,16644,6),(“apache2”,16643,6),(“apache2”,16641,6),(“apache2”,1077,6))
LISTEN 0 128 :::80 :::* users:((“apache2”,16747,4),(“apache2”,16700,4),(“apache2”,16686,4),(“apache2”,16683,4),(“apache2”,16652,4),(“apache2”,16651,4),(“apache2”,16645,4),(“apache2”,16644,4),(“apache2”,16643,4),(“apache2”,16641,4),(“apache2”,1077,4))
LISTEN 0 128 :::443 :::* users:((“apache2”,16747,8),(“apache2”,16700,8),(“apache2”,16686,8),(“apache2”,16683,8),(“apache2”,16652,8),(“apache2”,16651,8),(“apache2”,16645,8),(“apache2”,16644,8),(“apache2”,16643,8),(“apache2”,16641,8),(“apache2”,1077,8))
sudo /home/user/local/certbot-auto renew
/home/user/local/certbot-auto has insecure permissions!
To learn how to fix them, visit Certbot-auto deployment best practices
/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/cryptography/hazmat/primitives/constant_time.py:26: CryptographyDeprecationWarning: Support for your Python version is deprecated. The next version of cryptography will remove support. Please upgrade to a release (2.7.7+) that supports hmac.compare_digest as soon as possible.
utils.PersistentlyDeprecated2018,
Processing /etc/letsencrypt/renewal/www.darzeliai.panevezys.lt.conf
http-01 challenge for darzeliai.panevezys.lt
http-01 challenge for www.darzeliai.panevezys.lt
Waiting for verification…
^[[A^[[A^[[AChallenge failed for domain darzeliai.panevezys.lt
Challenge failed for domain www.darzeliai.panevezys.lt
Attempting to renew cert (www.darzeliai.panevezys.lt) from /etc/letsencrypt/renewal/www.darzeliai.panevezys.lt.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/www.darzeliai.panevezys.lt/fullchain.pem (failure)
Apache/2.4.7
Ubuntu 14.04.5 LTS
no
certbot 1.3.0
for some strange reason I can’t connect to your server on ports 80 and 8080. (443 works)
can you?
How to delete this topic as I got message “You don’t have permission to delete this topic. If you really want it to be deleted, submit a flag for moderator attention together with reasoning.”?
