I installed bigbluebutton on a dedicated server without firewall and with a pubblic IP, I registered the dns name on a third level domain aulesaf.pclinkitalia.com which correctly points to the IP address of the server that publishes bigbluebutton, I installed letsencrypt and I follow all the steps to generate the ssl Key, but when I try to connect to the webpage, mozzilla sad PR_END_OF_FILE_ERROR and chrome say connection close
My domain is:aulesaf.pclinkitalia.com
I ran this command: sudo certbot --nginx
root@ubuntu:~$ sudo certbot --nginx
blank to select all options shown (Enter ‘c’ to cancel): 1
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/aulesaf.pclinkitalia.com.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Deploying Certificate to VirtualHost /etc/nginx/sites-enabled/bigbluebutton
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Redirecting all traffic on port 80 to ssl in /etc/nginx/sites-enabled/bigbluebutton
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains:
https://aulesaf.pclinkitalia.com
https://www.ssllabs.com/ssltest/analyze.html?d=aulesaf.pclinkitalia.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/aulesaf.pclinkitalia.com/fullchain.pem
/etc/letsencrypt/live/aulesaf.pclinkitalia.com/privkey.pem
Your cert will expire on 2020-01-30. To obtain a new or tweaked
with the “certonly” option. To non-interactively renew all of
your certificates, run “certbot renew” -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): Tomcat 7
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: dedicated server on aruba
or certbot-auto --version
if you’re using Certbot): 0.31.0-1+ubuntu16.04.1+certbot+1
thanks for your help
