The requested apache plugin does not appear to be installed
My domain is: iwastrel.com
It produced this output: The requested apache plugin does not appear to be installed
My web server is (include version): apache2 (2.4.18-2ubuntu3.17)
The operating system my web server runs on is (include version): Ubuntu 16.04.7 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.27.0
Addendum: I ran 'sudo snap install --classic certbot' and got 'error: unable to contact snap store' Snap and snapd are installed.
I installed certbot using apt.
Hi @Wastrel, and welcome to the LE community forum :slight_smile:
That is an ancient version.
If that's all apt can find, then I would suggest that you should try using an alternate ACME client.
Like: acme.sh
Thank you, Rudy. That's a start. acme.sh has registered me but can't install the certificate because it doesn't have permission to write to /var/www/html. And it won't let me use sudo, but I will find a way to do it.
[Later] I created the directory it was looking for (/var/www/html/.well-known) and gave myself write permissions. Then I successfully obtained the certificate:
Wed Sep 28 15:49:56 CDT 2022] Your cert is in: /home/wastrel/.acme.sh/iwastrel.com/iwastrel.com.cer
[Wed Sep 28 15:49:56 CDT 2022] Your cert key is in: /home/wastrel/.acme.sh/iwastrel.com/iwastrel.com.key
[Wed Sep 28 15:49:56 CDT 2022] The intermediate CA cert is in: /home/wastrel/.acme.sh/iwastrel.com/ca.cer
[Wed Sep 28 15:49:56 CDT 2022] And the full chain certs is there: /home/wastrel/.acme.sh/iwastrel.com/fullchain.cer
That all looked good. Then I ran:
./acme.sh --install-cert --domain iwastrel.com
and there were no error messages.
Now I can go to https://www.iwastrel.com/ and... I have an issue on the internal network with my firewall and its proxy connection to the web server, but I think I know what it is.
The instructions are never enough!
Thanks for your help.
