Hi All,
The https SSL Certificate is not working for my site. https://shinesbudget.com. I have applied renew process also and its say valid till 2023-02-10. Please help.
Thanks
Shine
Hi All,
Thanks
Shine
or certbot-auto --version
if you're using Certbot):
Please try reloading your webserver:
sudo nginx -s reload
OR
reboot
My domain is: shinesbudget.com I ran this command: sudo certbot renew --cert-name shinesbudget.com --dry-run It produced this output: Certificate generated successfully My web server is (include version): nginx version: nginx/1.18.0 (Ubuntu) The operating system my web server runs on is (include version): Ubuntu 20.0 My hosting provider, if applicable, is: AWS Route 53 I can login to a root shell on my machine (yes or no, or I don't know): Yes I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.32.0
I have already rebooted my web server.
Using --dry-run
will only test renewal using the staging server without actually getting a renewed "real" certificate.
That said on crt.sh | shinesbudget.com I can see you did actually renew the cert yesterday.
Please post the output of sudo certbot certificates
root@ip-172-26-3-147:/etc/letsencrypt/renewal# sudo certbot certificates
Found the following certs:
Certificate Name: shinesbudget.com
Serial Number: 46750f8fbc54d63e5d1fc79be21c448a7b8
Key Type: RSA
Domains: shinesbudget.com
Expiry Date: 2023-02-10 11:51:08+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/shinesbudget.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/shinesbudget.com/privkey.pem
So you already have a valid, up to date certificate. It's just not being used by nginx.
Please post the output of the command sudo nginx -T
ubuntu@ip-172-26-3-147:~$ sudo nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/fm:
server_name 3.96.128.110 shinesbudget.com;
location /static {
alias /home/ubuntu/fmapi/static;
location /media {
alias /home/ubuntu/fmapi/media;
location ~ ^/(api|admin|api-auth|docs) {
# proxy_pass http://127.0.0.1:8000;
include /etc/nginx/proxy_params;
client_max_body_size 10M;
proxy_read_timeout 1800s;
proxy_pass http://unix:/home/ubuntu/fmapi/app.sock;
root /home/ubuntu/fmweb/dist/;
index index.html;
ssl_certificate /etc/letsencrypt/live/shinescert/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/shinescert/privkey.pem; # managed by Certbot
if ($host = shinesbudget.com) {
} # managed by Certbot
listen 80;
# configuration file /etc/nginx/proxy_params:
proxy_set_header Host $http_host;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file. Contents are based on https://ssl-config.mozilla.org
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384";
The certificate being used isn't the one being renewed:
should be:
