qa-tic-backend.com
sudo certbot certonly -v
--manual
--preferred-challenges dns
--manual-auth-hook "./../validate.sh"
--deploy-hook "./../deploy.sh "
--manual-cleanup-hook "./../cleanup.sh "
--disable-hook-validation
--noninteractive
--server https://acme-v02.api.letsencrypt.org/directory
--force-renewal
--email ...
--agree-tos
--domain $DOMAIN
I used this command with flag --test-cert before. I was able to update let's encrypt staging certificates on my Azure key vault with that.
Then I removed flag --test-cert and added flag --server https://acme-v02.api.letsencrypt.org/directory. I wanted to replace the staging certificate with a production certificate.
This does not work. I still only get staging certificates.
The command is called in a Github action workflow on a Github runner with static IP.
or certbot-auto --version
if you're using Certbot):
I do not know. In the Github workflow certbot is installed like: sudo snap install certbot --classic before the command from above is called.
