Ssl certicifate 'not secure' problem
My domain is: www.iamchaeyoung.com
The operating system my web server runs on is (include version):windows10
My hosting provider, if applicable, is: aws lightsail
Hi, I'm a real beginner...
I've made a website for assignment and was trying to get a ssl certificate through certbot.
I think I somehow succeed to get one, yet another problem has just occurred which is..
why is it still not secure? It says the provider is (STAGING) Artificial Apricot R3.
Should I get another new ssl certificate or have I done something wrong?
I got the source from here: https://raw.githubusercontent.com/wmnnd/nginx-certbot/master/init-letsencrypt.sh
Please help me. as I'm slowly dying.
Thank you.
Hello @Teetotal welcome to the community!
You have a staging cert installed.
Screenshot_2021-07-28_08-54-41
The staging server is for testing to be ready to do a "production run" and obtain a real certificate. Thank you for using the staging environment initially.
You can re-run your process and select the production server:
https://acme-v02.api.letsencrypt.org/directory
You did nothing wrong. No "Dying" allowed there's enough of that going around.
Hope this helps.
In the script used by OP this is done by editing the script and changing it:
staging=0 # Set to 1 if you're testing your setup to avoid hitting request limits
To:
staging=1 # Set to 1 if you're testing your setup to avoid hitting request limits
After changing the above you can re-run the script and all should be fine.
Note that the init-letsencrypt script should be run just once for getting a valid certificate. Once you have the valid certificate, you should NOT run the script again, as it will delete the previously issued, perfectly fine certificate and re-issue a new one unnecessarily. However, the Github repository nor the script does NOT explain how to renew your certificate, which is very unfortunate. Personally, I think the script is just plain @()$$)#@#* and shouldn't be used.
As I don't have experience with Docker nor that script, I find it hard to advice on how to proper renew your certificate and afterwards reload nginx too.
Good catch @Osiris , Thanks!
