Hi
I have been trying to get letsencrypt to work on an AWS EC2 instance which I understand is “experimental”. When I issue:
sudo ./letsencrypt-auto --debug
I get the following:
Creating virtual environment...
Updating letsencrypt and virtual environment dependencies......Command
"/root/.local/share/letsencrypt/bin/python2.7 -c "import setuptools,
tokenize;__file__='/tmp/pip-build-lGncaX/cffi/setup.py';
exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))"
install --record /tmp/pip-jdYQdp-record/install-record.txt
--single-version-externally-managed --compile --install-headers
/root/.local/share/letsencrypt/include/site/python2.7/cffi"
failed with error code 1 in /tmp/pip-build-lGncaX/cffi
Anyone else encountered the same and have a fix?
Thanks
