Suddenly 502 bad gateway on Certificate after working well for long time
My domain is: http://supershot.click/
It produced this output: 502 bad gateway
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.6 LTS (GNU/Linux 5.15.0-1030-aws x86_64)
My hosting provider, if applicable, is: AWS
What makes you think the problem is related to your SSL certificate? SSL/HTTPS appears to be working just fine on your server.
I would guess that the 502 has some unrelated cause.
This normally means your web server is configured to pull it's content from something else (reverse proxy), like another application server on the same machine or a different machine. If that other service stops running then your nginx can't proxy that information anymore.
