Stupidity of using certificate generation from docker temporary machine
certbot --nginx -n --agree-tos -d meak-stories.com -m {my e-mail}
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: meak-stories.com: see https://letsencrypt.org/docs/rate-limits/
Using docker image nginx
Inside docker...?
using root
no
The latest existent
I make something I just discovered was stupid: I was running the certbot inside my docker machine, while testing uploading my image and adding it to ECS of AWS.
I know, I was punished because I deserve that, but I would like to know: when this period ends? Can I cleanup my mess some way? The certificates are gone, with docker images (already read this was the wrong way to do this)
The next time this certificate can be issued is 19 Feb 2021 21:12:40 UTC.
That's 5-ish days from now.
You could evade the limit by including a subdomain:
-d meak-stories.com -d www.meak-stories.com
But remember to save the contents of /etc/letsencrypt this time!
WOW! Thanks for the quick answer!!!
I will add some lines to the script in a way that the certificate is safe and sound now.
