Too many certificates already issued for exact set of domains:
edscloud.org
N/A Deployed a container
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains
My web server is (include version): Docker container
The operating system my web server runs on is (include version): Centos 7
My hosting provider, if applicable, is: DigitalOcean
certbot --version
certbot 1.0.0
So, I screwed up. I was deploying docker containers for LetsEncrypt, MariaDB and NextCloud (for the first time as a noob). In my troubleshooting (because I kept getting database errors unrelated to LetsEncrypt) I snapshot the VPS and kept restoring the snapshot without saving off the certificate. Now, in my final deployment I am seeing the error in the LetsEncrypt docker logs.
Doing some Google searches I found other post on the same issue and found this site to view my certificate list: https://crt.sh/?q=edscloud.org
My question(s): Looking at the site, how do I interpret that list? Is there a way to tell when is the next time I can generate another certificate outside the limit so that I can deploy my NextCloud site? I believe I have found my database issue and this should be the last time I deploy the containers and generate a certificate.
Never mind. It looks as if the following site is working and tells my the next time is on the 14th, right?:
https://check-your-website.server-daten.de/?q=edscloud.org
Hi @t3kg33k
yes, that's correct.
But if you use a docker container, you should use a permanent device to save Certbot and all certificates. So you can re-use the account and the certificates if you destroy your container.
So you have to wait.
Or use the test system.
