There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains:
My domain is: doc.rebis-online.ru
I ran this command: sudo nextcloud.enable-https lets-encrypt
In order for Let’s Encrypt to verify that you actually own the
domain(s) for which you’re requesting a certificate, there are a
number of requirements of which you need to be aware:
  1. In order to register with the Let’s Encrypt ACME server, you must
    agree to the currently-in-effect Subscriber Agreement located
    here:
    https://letsencrypt.org/repository/
    By continuing to use this tool you agree to these terms. Please
    cancel now if otherwise.
  2. You must have the domain name(s) for which you want certificates
    pointing at the external IP address of this machine.
  3. Both ports 80 and 443 on the external IP address of this machine
    must point to this machine (e.g. port forwarding might need to be
    setup on your router).
Have you met these requirements? (y/n) y
Please enter an email address (for urgent notices or key recovery): to@303333.ru
Please enter your domain name(s) (space-separated): doc.rebis-online.ru
Attempting to obtain certificates… error running certbot:
Saving debug log to /var/snap/nextcloud/current/certs/certbot/logs/letsencrypt.log
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: doc.rebi s-online.ru: see https://letsencrypt.org/docs/rate-limits/
Please see the logfiles in /var/snap/nextcloud/current/certs/certbot/logs for more details.
My hosting provider, if applicable, is: personal server in the office
certbot --version
Command ‘certbot’ not found, but can be installed with:
apt install certbot
certbot-auto --version
certbot-auto: command not found
Hi @Rebis
there is a check of your domain, ~3 hours old - https://check-your-website.server-daten.de/?q=doc.rebis-online.ru#ct-logs
CertSpotter-Id Issuer not before not after Domain names LE-Duplicate next LE
912866042 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-15 07:02:29 2019-08-13 07:02:29 doc.rebis-online.ru
1 entries duplicate nr. 5 next Letsencrypt certificate: 2019-05-22 06:30:56
912856392 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-15 06:55:48 2019-08-13 06:55:48 doc.rebis-online.ru
1 entries duplicate nr. 4
912838617 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-15 06:43:08 2019-08-13 06:43:08 doc.rebis-online.ru
1 entries duplicate nr. 3
912833798 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-15 06:39:31 2019-08-13 06:39:31 doc.rebis-online.ru
1 entries duplicate nr. 2
912823120 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-15 06:30:56 2019-08-13 06:30:56 doc.rebis-online.ru
1 entries duplicate nr. 1
896681617 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-05-06 05:49:00 2019-08-04 05:49:00 doc.rebis-online.ru
1 entries
You have created 5 identical certificates.
Where are these?
Please check the documentation of nextcloud.enable-https lets-encrypt to find these certificates and to use one.
Your domain is invisible:
• http://doc.rebis-online.ru/
85.192.165.221 -8 0.346 W
ConnectionClosed - The underlying connection was closed: The connection was closed unexpectedly.
• https://doc.rebis-online.ru/
85.192.165.221 -4 0.343 W
SendFailure - The underlying connection was closed: An unexpected error occurred on a send. Authentication failed because the remote party has closed the transport stream.
• http://doc.rebis-online.ru:443/
85.192.165.221 -8 0.350 A
Visible Content:
• http://doc.rebis-online.ru/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
85.192.165.221 -8 0.354 W
Visible Content:
So it's impossible to see your configuration.
Of the old server NEXTCLOUD there were problems and we deleted it. Created a new server and request a certificate SSL.
