I created certificate 5 times in one week. When i try to create another one i get error. I know i can not create certificate more than 5 in one week but is there a way to use created certificate for my website ? because i could not use certificates that i created before because first time i use ssl in my website and i did not notice to limit. If is there a way please help me.
Thank you
My domain is: vultuskjkszpj.online
I ran this command: docker-compose -f docker-compose.deploy.yml run --rm certbot /opt/certify-init.sh
An unexpected error occurred:
Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: vultuskjkszpj.online, retry after 2022-12-15T19:43:47Z: see Duplicate Certificate Limit - Let's Encrypt
ERROR: 1
My web server is : nginx:1.23.0-alpine
I used Docker and Nginx with Python project python:3.11.0-slim
The operating system my web server runs on is : nginx:1.23.0-alpine
I can login to a root shell on my machine
I'm using a control panel to manage my site
The version of my client is certbot/certbot:v1.27.0
Yes, we can help you but we need more info. please answer the questions as best you can
Of course there is, if you still have it and its corresponding private key. The cert is easy to get (you can get a copy from crt.sh if you've lost yours), but the private key is, well, private, and if you've destroyed it, the cert that goes with it won't do you any good.
Hi danb35,
Thanks for answer. I can see my certificate list from crt.sh. but i dont know how to use it. Can you give me more specific detail ?
Thank you
ls -lr /etc/letsencrypt/archive/* I run this code without archive because no such a file or directory.
When i run the code i get these result
If i have private key how can i use with public certs from crt.sh
Do you have a backup or a snapshot that contains that folder?
In a few more hours you will be able to get a new cert.
Before you do that, you should work on your system to make sure it can save the cert.
That the cert can survive a system reboot.
You should also do all your testing on the staging environment - not the live production system.
