SSL Works on iOS devices but not on PC Browsers
My domain is: https://NissanLEAFbatteryReplacement.com/
I ran this command: www.NissanLEAFbatteryReplacement.com in my Safari & IE on my Windows PC
It produced this output: not secure
My web server is (include version): 1and1.com Plesk Obsidian
Version 18.0.29 Update #2, last updated on Aug 26, 2020 05:55 AM
The operating system my web server runs on is (include version): Server 2019
My hosting provider, if applicable, is: 1and.com
I can login to a root shell on my machine (yes or no, or I don’t know): No
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Obsidian Version 18.0.29
Hi @UBUYGAS
see your screenshot: Your certificate is valid. But you have mixed content - see https://check-your-website.server-daten.de/?q=nissanleafbatteryreplacement.com#html-content
Two images loaded via http:
http://leaf380.com/LEAfs.jpg
http://NissanLEAFbatteryReplacement.com/contact_me.jpg
the same with og-elements. Must be https.
Wow! Had no idea, this is my first attempt at SSL Cert on a website. I will edits those and report back, thanks!
Wow! That was easy!
I owe you a Beer!
Thanks!!!
WOW_That_was_easy!
That's a standard problem if a website is changed from http to https. All http links must be changed.
Or just remove the protocol alltogether from all URI's. That would force the client to use the same protocol as the origin. I.e., change http://example.com/foo/bar.html to //example.com/foo/bar.html
