SSL/TLS Certificates not secured
My domain is: https://urbnsocial.com/
I ran this command: Did not ran any command and don't know how to.
It produced this output: Please wait while Plesk finishes adding a DNS record with the following parameters:
Record type: TXT
Domain name: _acme-challenge.urbnsocial.com
Record: 6e2A1qD6vG0tJO0jcXc-ShZofZ00ADJq0BCovNQMC7c
The current SSL/TLS certificate is valid to January 21, 2021. It will be used to secure your website until a new one is issued.
My web server is (include version): I don't know
The operating system my web server runs on is (include version): Windows 10
My hosting provider, if applicable, is: Plesk
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): Not sure
Hi @ShinjiPerado
Plesk isn't your hoster, Plesk is your control panel. Your configuration is a little bit tricky - see your check this morning - https://check-your-website.server-daten.de/?q=urbnsocial.com
Host Type IP-Address is auth. āˆ‘ Queries āˆ‘ Timeout
urbnsocial.com A 51.79.79.183 Beauharnois/Quebec/Canada (CA) - OVH SAS Hostname: ns568953.ip-51-79-79.net yes 1 0
AAAA yes
www.urbnsocial.com CNAME u9wxuwu.sitelockcdn.net yes 1 0
A 45.60.23.104 London/England/United Kingdom (GB) - Incapsula Inc
No Hostname found yes
Non-www and www have different ip addresses.
Your www version has a Plesk (see the #Portcheck - part).
Your www has a correct GlobalSign - certificate, your non-www has the expired certificate.
So: Who manages your non-www hosting? Looks like OVH or a subprovider, so must that company manage / fix the Plesk running there -> ask OVH or your subprovider.
