SSL renew problem
chikan.tours (but the name of my ssl is another name ? strange)
sudo -H ./letsencrypt-auto certonly --standalone -d chikan.tours
no matter how i update… it just create ssl like chikan.tour-0001 chikan.tour-0002, my ssl does not renew at all. is there anyway to help me to renew my ssl ?
apache
php 7.0
linode
Hi @wuouxiang
you have created 3 new identical certificates ( https://check-your-website.server-daten.de/?q=chikan.tours ):
CRT-Id Issuer not before not after Domain names LE-Duplicate next LE
1383535936 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-14 00:17:04 2019-07-13 00:17:04 chikan.tours duplicate nr. 3
1383502472 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-13 23:59:47 2019-07-12 23:59:47 chikan.tours, penghu.wiki duplicate nr. 2
1383500391 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-13 23:58:15 2019-07-12 23:58:15 chikan.tours, penghu.wiki duplicate nr. 1
1383450382 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-13 23:26:34 2019-07-12 23:26:34 chikan.tours duplicate nr. 2
1383429508 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-04-13 23:16:58 2019-07-12 23:16:58 chikan.tours duplicate nr. 1
1196476881 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-02-12 00:32:33 2019-05-12 23:32:33 chikan.tours
1165969029 CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US 2019-02-01 23:24:26 2019-05-02 22:24:26 chikan.tours, penghu.im, penghu.info, penghu.news, penghu.wiki
Three with chikan.tours, two with chikan.tours + penghu.wiki.
What says
sudo ./letsencrypt-auto certificates
You have used certonly, so you have to install the certificate manual.
But your domain uses
CN=penghu.wiki
	02.02.2019
	03.05.2019
expires in 19 days
penghu.news, penghu.wiki - 5 entries
with 5 domain names.
Thank you so much for your helping. so…what command should I do next… or How could I solve this problem ? I want to remove (CN=penghu.wiki with 5 domain) but I dont know how to delete it ? thank you
How did you installed the certificate you use? Do that again.
certonly doesn't install the certificate.
Ignore it. If you install a new certificate (question 1), the certificate is removed. This is one step.
Hi I really appreciate you for your kind help
so far…the way I update ssl is – > sudo -H ./letsencrypt-auto certonly --standalone -d chikan.tours
i really always did it for ( I learned from https://www.linode.com/docs/security/ssl/install-lets-encrypt-to-create-ssl-certificates/)
so… you mean I can remove certonly … and just “sudo -H ./letsencrypt-auto --standalone -d chikan.tours” right ? thank you
I don't know if that works.
First, you use letsencrypt-auto, that's very old.
What says
letsencrypt-auto --version
Second, you use standalone, not a running webserver. So I don't know if that old letsencrypt-auto knows something about your webserver.
Your non-www + https uses an Apache
Server: Apache/2.4.18 (Ubuntu)
A newer Certbot is able to install the certificate.
Perhaps try
sudo ./letsencrypt-auto -d chikan.tours
and check, if your client sees the new certificate and asks, if you want to install it. That's a feature of newer Certbot-versions.
Or check
to update. Current version is 0.33.
