Problem with Renewing all websites
Hello,
my Debian 8 + Apache server runs multiple domains and automatically redirects http to https. From time to time, I want to renew my SSL certificates. So I manually run “sudo /usr/local/bin/certbot-auto --apache”, and it asks me “Which names would you like to activate HTTPS for?”
Strangely, one of the domains it recognizes is: “7: xxx.xxx.xxx.xxx”
If I only renew domains 1-6, everything works. If I renew all domains, including 7, it doesn’t work. It tries to renew domain 7’s certificate first and gives the following error:
(E)xpand/©ancel: e
http-01 challenge for xxx.xxx.xxx.xxx
Waiting for verification…
Challenge failed for domain xxx.xxx.xxx.xxx
   Domain: xxx.xxx.xxx.xxx
   Type:   unauthorized
   Detail: Invalid response from
   https://www.xxx.xxx/.well-known/acme-challenge/6PbO5eGCNPkqtDwzpjGN3xMOnuepoZ        Saq8g1RA6P2Qk
   [52.206.55.67]: "<!DOCTYPE html>\n<html>\n  <head>\n    <!-- Google
   Tag Manager -->\n
   <script>(function(w,d,s,l,i){w[l]=w[l]||[];w[l].push({'gtm.s"
Can someone please help me fixing this? Thanks!
I think I must delete some file or entry or folder to get rid of domain 7 (which is actually not a real domain, but some strange thing that letsencrypt recognizes)…
As a result, I also can’t auto-refresh my certificates …
Hi @feufu
please answer all of the following questions:
Hi, here is the data:
My domain is: One of the websites is tplinvestors.com
I ran this command: See above, “sudo /usr/local/bin/certbot-auto --apache”
It produced this output: See above
My web server is (include version): Debian 8.11
The operating system my web server runs on is (include version): Debian 8.11
My hosting provider, if applicable, is: Netcup
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.0.0
What's the xxx - domain? Is this a masked domain or is this really xxx.xxx?
Checking your main domain there is one certificate with 6 domain names, that looks ok ( https://check-your-website.server-daten.de/?q=tplinvestors.com ).
Last from 2019-11-22.
Ah - the xxx.xxx.xxx.xxx domain has two ip addresses - https://check-your-website.server-daten.de/?q=xxx.xxx.xxx.xxx
xxx.xxx.xxx.xxx A 52.22.77.136 Ashburn/Virginia/United States (US) - Amazon.com, Inc. Hostname: ec2-52-22-77-136.compute-1.amazonaws.com yes 1 0
A 52.206.55.67 Ashburn/Virginia/United States (US) - Amazon.com, Inc. Hostname: ec2-52-206-55-67.compute-1.amazonaws.com yes 1 0
AAAA yes
www.xxx.xxx.xxx.xxx A 52.22.77.136 Ashburn/Virginia/United States (US) - Amazon.com, Inc. Hostname: ec2-52-22-77-136.compute-1.amazonaws.com yes 1 0
AAAA yes
The ip 52.206.55.67 is checked, see your error message:
And your own domain has a completely different ip address:
tplinvestors.com A 93.177.65.12 Karlsruhe/Baden-Württemberg/Germany (DE) - netcup GmbH Hostname: v22019074412592395.happysrv.de yes 1 0
AAAA yes
www.tplinvestors.com A 93.177.65.12 Karlsruhe/Baden-Württemberg/Germany (DE) - netcup GmbH Hostname: v22019074412592395.happysrv.de yes 1 0
AAAA yes
So it's something like a wrong sample domain in your config file.
What says
apachectl -S
There you should see the vHost definition with the xxx.xxx domain.
  • If it is a ServerAlias -> remove it.
  • If it is a vHost, disable that vHost
  • Restart your server
Then again apachectl -S to see, if it had worked.
Thanks, the "apachectl -S" command helped me a lot! I think it was a vHost definition that shouldn't be there, some files in the folder. I removed those files, now the vHost isn't defined any more and renew works perfectly! Thanks again, Jürgen!
