Ssl renew problem
i am facing this problem can any body help me on this .
[root@www sites-available]# certbot renew
Processing /etc/letsencrypt/renewal/sonicfiber.pk-0001.conf
tls-sni-01 challenge for sonicfiber.pk
tls-sni-01 challenge for www.sonicfiber.pk
Attempting to renew cert (sonicfiber.pk-0001) from /etc/letsencrypt/renewal/sonicfiber.pk-0001.conf produced an unexpected error: Problem binding to port 443: Could not bind to IPv4 or IPv6… Skipping.
Processing /etc/letsencrypt/renewal/sonicfiber.pk.conf
Cert not yet due for renewal
/etc/letsencrypt/live/sonicfiber.pk-0001/fullchain.pem (failure)
/etc/letsencrypt/live/sonicfiber.pk/fullchain.pem expires on 2019-02-06 (skipped)
You’re using the standalone plugin authenticator, which spins up its own webserver on port 80 (for the currently recommended http challenge) or on port 443 (for the deprecated tls-sni challenge you’re currently using). But it seems another application is listening on your port 443. And probably on your port 80 too.
Is that the case?
can you help me out in this case
[root@www ~]# netstat -nap | grep 80
tcp 0 64 202.63.197.101:2222 202.63.215.48:56805 ESTABLISHED 59907/sshd: root@pt
tcp6 0 0 :::80 :::* LISTEN 41830/httpd
tcp6 0 1 2400:1a80::20c:29:42684 2a04:4e42:400::223:443 SYN_SENT 42248/python2.7
unix 2 [ ACC ] STREAM LISTENING 17980 1467/master private/lmtp
unix 3 STREAM CONNECTED 5731800 772/dbus-daemon /var/run/dbus/system_bus_socket
unix 2 DGRAM 18009 1060/snmpd
[root@www ~]# netstat -nap | grep 443
tcp6 0 0 :::443 :::* LISTEN 41830/httpd
[root@www ~]#
Osiris
still waiting for your response on it.
Hi @fayaz
the tls-sni-01 is deprecated. So don't use it.
certbot renew --preferred-challenges http
If this doesn't work, share your log and add the --debug-challenges - parameter to find the place where certbot saves the file.
https://certbot.eff.org/docs/using.html
--debug-challenges After setting up challenges, wait for user input before submitting to CA
hi
i tried it as well but its does work can you help me on that…
[root@www acme-challenge]# certbot renew --preferred-challenges http --debug-challenges
http-01 challenge for sonicfiber.pk
http-01 challenge for www.sonicfiber.pk
Waiting for verification…
Challenges loaded. Press continue to submit to CA. Pass “-v” for more info about
challenges.
Attempting to renew cert (sonicfiber.pk-0001) from /etc/letsencrypt/renewal/sonicfiber.pk-0001.conf produced an unexpected error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error finalizing order :: too many certificates already issued for exact set of domains: sonicfiber.pk,www.sonicfiber.pk: see https://letsencrypt.org/docs/rate-limits/. Skipping.
Why do you want to renew a certificate if you have already 5 new certificates created today?
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:sonicfiber.pk&lu=cert_search
Your renew works.
If you use "Installer none", you have to install your certificate manual.
i couldn't get certificate ..how can i install that one.... can you help me and guide properly on this.
Check your certificates with
certbot certificates
And read
Now
your non-www is correct. But your www uses the wrong certificate, only with the non-www domain name.
But you have certificates with two names, created today:
https://transparencyreport.google.com/https/certificates/J63jd4XvLTz4zoAQLaKvuszmD9fwcYg4izqM9Mo8Msc%3D
So use certbot certificates to find one of these and use this certificate.
I'm in timezone CET (UTC+1), my post was made just before I left for work, so yes, you were waiting :slight_smile:
@JuergenAuer He's using the standalone plugin but also has a webserver running on port 80. So changing from tls-sni to http doesn't really work, @fayaz needs to change the authenticator plugin to either apache/nginx or the webroot plugin.
@fayaz Is there a specific reason you're running the standalone plugin? Did you use some sort of guide the first time you issued a certificate? If so, which one? Also, which webserver are you running?
That looks like your running apache on ports 80 and 443.
So you should NOT be using --standalone
Try:
certbot renew --apache --preferred-challenges http
If you run into any problems, please show:
certbot --version
apache2 -v
