Issue to renew?
i was wondering if someone else has had the same issue currently have a subdomain working with letsencrypt. The issue is that when i try to renew im getting this error
Attempting to renew cert (platform.mydomain.cloud) from /etc/letsencrypt/renewal/platform.mydomain.cloud.conf produced an unexpected error: Failed authorization procedure. platform.mydomain.cloud (tls-sni-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Error getting validation data. Skipping.
  /etc/letsencrypt/live/platform.mydomain.cloud/fullchain.pem (failure)
odd because i have not made any A records new and i can access the site with no issue. i was looking though google Most people has this issue was because they were using IPV6, i did a curl platform.mydomain.cloud and works fine. at the end i was reading that i should update cert bot but not sure what repository i should use?
This is the command when i initially run the cert
 sudo certbot --nginx --agree-tos --redirect --staple-ocsp --email myemail@mydomain.cloud -d platform.mydomain.cloud
then this to run the update cron task
30 2 * * 1 certbot renew --post-hook "systemctl reload nginx" >> /var/log/le-renew.log
Hi @killmasta93
is this a new domain?
tls-sni-01 is deprecated and you can't use it with new domains.
Support ends 2019-02.
What else does “sudo certbot renew” output?
What’s the real domain?
Thanks for the reply its not a new domain. the domain is platform.syncbox.cloud
Thanks for the reply this is what i ge t
Processing /etc/letsencrypt/renewal/platform.syncbox.cloud.conf
tls-sni-01 challenge for platform.syncbox.cloud
    Attempting to renew cert (platform.syncbox.cloud) from /etc/letsencrypt/renewal/platform.syncbox.cloud.conf produced an unexpected error: Failed authorization procedure.   platform.syncbox.cloud (tls-sni-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Error getting validation data. Skipping.
  /etc/letsencrypt/live/platform.syncbox.cloud/fullchain.pem (failure)
Then try it with
sudo certbot renew --preferred-challenges http
Thanks for the reply im getting this
 http-01 challenge for platform.syncbox.cloud
  Using default address 80 for authentication.
 Attempting to renew cert (platform.syncbox.cloud) from /etc/letsencrypt/renewal/        platform.syncbox.cloud.conf produced an unexpected error: Failed authorization p        rocedure. platform.syncbox.cloud (http-01): urn:ietf:params:acme:error:unauthori        zed :: The client lacks sufficient authorization :: Invalid response from http:/        /platform.syncbox.cloud/.well-known/acme-challenge/q0Ih1Cbr4OtYk18wv-fMbtXjdd-S8        Qw4kzIV2e_MPRQ [190.145.225.174]: 404. Skipping.
Please share your complete log under
/var/log/letsencrypt/letsencrypt.log
You have a redirect http -> https (checked via https://check-your-website.server-daten.de/?q=platform.syncbox.cloud ).
So the Letsencrypt - validation is redirected to https. Is this the server Certbot creates the /.well-known/acme-challenge directory and saves the validation file?
Add
--debug-challenges    After setting up challenges, wait for user input
                        before submitting to CA
and check, where this file is created and if this file is visible via port 80 or the redirect.
Thanks for the reply, i currently have HAproxy which does the redirect from http to https but whats odd is that i have never had this issue before prob because tls-sni-01 is deprecated
https://pastebin.com/mjXa04yQ
There you have your error:
Detail: Invalid response from http://platform.syncbox.cloud/.well-known/acme-challenge/_kOdRDfX_OZRIedqRGLZl08gniThfEslAYuejRE5P8Q [190.145.225.174]: 404
Letsencrypt doesn't find the validation file.
Did you use --debug-challenges to check where certbot creates such a file?
Or has your http version another webroot as your https version?
Thanks for the reply i ran this
           certbot renew --preferred-challenges http --debug-challenges --dry-run
then got this
    Attempting to renew cert (platform.syncbox.cloud) from /etc/letsencrypt/renewal/platform.syncbox.cloud.conf produced an unexpected error: Failed authorization procedure. platform.syncbox.cloud (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://platform.syncbox.cloud/.well-known/acme-challenge/hn9_Xr_p-fH9QKL8Jw-u0gkwDyYo6jQc93tvgL7kp3g [190.145.225.174]: 404. Skipping.
  /etc/letsencrypt/live/account.syncbox.cloud/fullchain.pem (failure)
i installed using this commands
apt install software-properties-common
add-apt-repository ppa:certbot/certbot
apt update
apt install certbot python-certbot-nginx
sudo certbot --nginx --agree-tos --redirect --staple-ocsp --email myemail@syncbox.cloud -d platform.syncbox.cloud
what odd is that i have another server which is running ubuntu 14 instead i used this
sudo wget https://dl.eff.org/certbot-auto
sudo chmod a+x /usr/local/sbin/certbot-auto
certbot-auto certonly -a webroot --webroot-path=/var/www/html -d mydomain.com -d www.mydomain.com
and it works with no issue so i guess its not an HAproxy issue
Did you check where Certbot has saved the validation file? --debug-challenges waits so you can check this.
Don't hit "Return" (or "Space") before you didn't found the file in the directory.
Thanks for the quick reply
this is the whole outcome
root@users:~# certbot renew --debug-challenges
Processing /etc/letsencrypt/renewal/account.syncbox.cloud.conf
Cert not yet due for renewal
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
/etc/letsencrypt/live/account.syncbox.cloud/fullchain.pem expires on 2018-12-17 (skipped)
Domain: platform.syncbox.cloud
Type: connection
Detail: Error getting validation data
i found a folder inside of /var/www/html the folder which is the .well-known but its empty
(see picture)
08-002
Thank you again
If you use the tls-sni-01 - validation, then there is no file created.
thanks for the reply, so the question is what is the correct command to run to renew the ssl? or what do i need to do?
As written:
sudo certbot renew --preferred-challenges http --debug-challenges --dry-run
The tls is deprecated, dead. No chance to debug / fix that. So http or dns.
Thanks for the reply, what i needed was this on the NGINX config
 location ~ /.well-known {
            allow all;
so this is to renew,
what about when its the first time?
be something like this?
          certbot --preferred-challenges http
Your first command must have all informations.
So you can try
sudo certbot -d yournewdomain
and answer the questions certbot asks. Then these informations are saved in your configuration file.
Or you use something like
sudo certbot -d yournewdomain --nginx --preferred-challenges http
--debug-challenges requires manual action, so you don't want to use it in a cron job.
Thanks for the reply, will use this in the future on a new domain.
so for the cronjob would be something like this?
       30 2 * * 1      certbot renew --preferred-challenges http "systemctl reload nginx" >> /var/log/le-renew.log
