Manual renewal faild
While we had a certificate for three months, now that it is expired, I get the following error when I manualy run “certbot renew”
Processing /etc/letsencrypt/renewal/DOMAIN.COM.conf
http-01 challenge for DOMAIN.COM
Attempting to renew cert (DOMAIN.COM) from /etc/letsencrypt/renewal/DOMAIN.COM.conf produced an unexpected error: Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.. Skipping.
  /etc/letsencrypt/live/DOMAIN.COM/fullchain.pem (failure)
Since there was a working certificate, why should I get this error now? Currently, we have the following entry in /etc/httpd/conf.d/ssl.conf
<VirtualHost _default_:443>
        SSLEngine on
        SSLCertificateFile /etc/letsencrypt/live/DOMAIN.COM/cert.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/DOMAIN.COM/privkey.pem
        SSLCACertificateFile /etc/letsencrypt/live/DOMAIN.COM/fullchain.pem
        <Directory "/var/www/html/">
        Options FollowSymLinks
        AllowOverride All
              Order allow,deny
              allow from all
              Require all granted
        </Directory>
        DocumentRoot /var/www/html/
Hi @mahmoodn
you have only a 443 vHost.
There
is your answer.
Create a port 80 vHost. There should be a template how to do that.
