SSL renew Issue
My domain was working perfectly fine with SSL Certificate. And then the certificate was expired and I'm trying to renew the certificate from virtual/web min panel. But the error comes:
There were too many requests of a given type :: Your account is temporarily prevented from requesting certificates
Please help me out to fix this. Why its not being renewed
Your client was keep asking LE for a new certificate, be it was never able to pass domain validation, so server got annoyed and no longer answering your request:
After that message there should be a long like to reactivate your account. Do that and post new message from your log
Generally there are only blocks like that after a lot of failed attempts.
I ran this command to try to get a certificate (feel free to include a screenshot if it's through a control panel):
It produced this output (please provide the entire output of the attempt, again you can use a screenshot if that's easiest):
Provide the name and version of the control panel you're using:
