SSL rate limits problem
hello my site gives such an error, How can I fix?
Error: {“type”:“urn:ietf:params:acme:error:rateLimited”,“detail”:“Error creating new order :: too many certificates already issued for exact set of domains: site.com,www.site.com: see https://letsencrypt.org/docs/rate-limits/","status”:429}
How do I delete old certificates
There's nothing you can delete that will affect the rate limits.
Can you use one of the other 5 certificates that have been issued recently?
I had to delete the server and cannot access certificates. Need to wait 1 week?
You had to delete the server five times within a week? If you're testing things out, you should use the testing environment with Let's Encrypt--that's what it's for.
One week from the time the first cert was issued.
