SSL on Ubuntu 16.04 with apache and varnish
Thus the “trick” I’ve been trying to supply.
Probably :smile:
/etc/varnish/default.vcl
# Default backend definition. Set this to point to your content server.
backend default {
    .host = "195.201.138.70";
    .port = "8080";
EDIT:
/etc/default/varnish
VARNISH_LISTEN_PORT=80
@_az I didn't make any changes yet. So, I should give in to the certonly , right? What about the previous certificate that I created?
Yes, but you could add (as I said earlier) another listener on another IP:80
Like:
Listen 127.0.0.123:80
that will suffice for the certbot listen port 80 check.
Then we simply face the check for FQDNs.
Which can be added as well.
I just need to grasp where…
Please show the apache.conf file.
If you already have a certificate issued, then you can just create a virtual host on Apache.
e.g.
<VirtualHost *:443>
  ServerName leptokaropoulos.gr
  ServerAlias www.leptokaropoulos.gr
  ProxyPass / http://localhost:80/
  ProxyPassReverse / http://localhost:80/
  SSLEngine on
  SSLCertificateFile      /etc/letsencrypt/live/leptokaropoulos.gr/cert.pem
  SSLCertificateChainFile /etc/letsencrypt/live/leptokaropoulos.gr/chain.pem
  SSLCertificateKeyFile   /etc/letsencrypt/live/leptokaropoulos.gr/privkey.pem
</VirtualHost>
I think I understand what @rg305 was suggesting now, sorry for the outburst :smiley:
rethinking this through...
Apache listens on 443 (https)
Proxies to port 80 (varnish) http
varnish proxies to 8080 also http.
Yes, this can work.
By seeing @_az 's response let me add this last thing (I don’t have a live folder inside /etc/letsencrypt):
etc/letsencrypt/
├── accounts
│   └── acme-v01.api.letsencrypt.org
│       └── directory
│           └── [random numbers and characters]
│               ├── meta.json
│               ├── private_key.json
│               └── regr.json
├── cli.ini
├── csr
│   └── 0000_csr-certbot.pem
├── keys
│   └── 0000_key-certbot.pem
├── options-ssl-apache.conf
├── renewal
└── renewal-hooks
    ├── deploy
    ├── post
    └── pre
Well, it will be necessary in the end in order to include Varnish in the request path, so if it does cause a loop, it’ll need to be fixed with x-forwarded-proto etc.
Looks like you haven’t created a certificate yet. Give it a try with the certonly command (or the way @rg305 suggested, up to you).
try:
certbot certificates
and please show the apache.conf file.
No certs found.
@rg305 do you mean ports.conf or apache2.conf ?
send both if you can
just remove any lines that start with #
Guys, I found this.
/etc/apache2/ports.conf:
Listen 8080
<IfModule ssl_module>
        Listen 443
</IfModule>
<IfModule mod_gnutls.c>
        Listen 443
</IfModule>
/etc/apache2/apache2.conf:
Mutex file:${APACHE_LOCK_DIR} default
PidFile ${APACHE_PID_FILE}
Timeout 300
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 5
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
HostnameLookups Off
LogLevel warn
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
Include ports.conf
<Directory />
        Options FollowSymLinks
        AllowOverride None
        Require all denied
</Directory>
<Directory /usr/share>
        AllowOverride None
        Require all granted
</Directory>
<Directory /var/www/>
        AllowOverride All
        Require all granted
</Directory>
<Directory /var/www/html/>
        AllowOverride All
        Require all granted
</Directory>
AccessFileName .htaccess
<FilesMatch "^\.ht">
        Require all denied
</FilesMatch>
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
IncludeOptional conf-enabled/*.conf
IncludeOptional sites-enabled/*.conf
Sure, you can use that article. It’s more or less what I was proposing.
The only problem with it is that it’s incompatible with --apache, you’d need to use certonly with --webroot before you setup the HTTPS listener.
The first design is exactly as @_az suggested.
Ok that was lacking...
I need to see what's in these:
try here first:
ls -l /etc/apache2/sites-enabled/
Probably just a default.conf file, if so, post that here.
Otherwise show the list and post them all!
/etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:8080>
        # specifies what hostname must appear in the request's Host: header to
        #ServerName www.example.com
        DocumentRoot /var/www/html
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
</VirtualHost>
EDIT:
ls /etc/apache2/conf-enabled/ :
charset.conf localized-error-pages.conf other-vhosts-access-log.conf security.conf serve-cgi-bin.conf
Yeah this (and ports.conf) is were it all happens
Could I make the following new entry (as mentioned from @_az), for simplicity, on ports.conf :
<VirtualHost *:443>
  SSLEngine on
</VirtualHost>
EDIT:
And then (or previously) create a new certificate by using certonly.
I would try this:
modify file
ports.conf
add
right after
Listen 8080
copy 000-default.conf to new file
cp /etc/apache2/sites-enabled/000-default.conf /etc/apache2/sites-enabled/127-80-default.conf
modify /etc/apache2/sites-enabled/127-80-default.conf
change
to
<VirtualHost 127.0.0.123:80>
restart apache web server
then let certbot do its’ thing.
