yes, you have two options
So, your solution enables me to create a certificate using --apache and @_az 's using certonly.
The question is, what to choose
Isn’t --apache just going to create a listener on 127.123:443 and that won’t be listening to the internet? IDK, I’ve never seen such a creative solution before. Good luck :P.
Of course I’m biased…
But if my solution works it is already setup for renewals.
Certonly would not be.
certonly also has autorenewal. You just need to add --post-hook "service httpd reload".
Yes the listener may need some love... after the Frankenstein operation!
As would his system, which currently hasn't loaded either of these:
It isn't yet capable of TLS (SSL)
The final fix would require just two changes:
Enable 443 in ports.conf (requires loading ssl modules)
and modifying the newly (certbot) created ssl conf file from:
<VirtualHost 127.0.0.123:443>
to
<VirtualHost 0.0.0.0:443>
I think I am a bit confused. Certificates need to renew every 90 days right? This is something that I would need. However, I would like to choose the easiest and more painless solution.
Both solutions are trying to get you a cert and set it up for autorenewals.
If there was a Varnish-ACME client this would have been solved long ago… LOL
The author of Varnish doesn’t believe (and further statement) HTTPS belongs in Varnish, sadly.
OK then, If there was a…
“Varnish friendly” ACME client or
certbot --apache-varnish parameter
then we wouldn’t be trying to invent this wheel.
So @markos, what have you decided?
What have you tried?
What have you learned?
Not much to be frank. I still don’t fully understand or know how to implement either approaches. This is my first contact with LE and SSL in general, so that’s why I am a bit slow and hesitant. However I need to secure my site, right?
As for your approaches/advices. I think I am going with the simpler solution (@_az 's) and if that doesn’t work, I will try your a-little-more-complicated (:P) approach.
I couldn’t thank you enough though, guys!
Ok, then start with getting a cert (using certonly method)
If that is successful you are half way there.
Remember: The changes you would be making should not affect the current HTTP site on port 80.
You would be adding another new method of access; HTTPS via port 443.
I know, however I am skeptical of the certificate creation. I think If I create one, I should use it, not matter what.
Check this also. I don’t know if this is something to think about, but, while reading the article I posted I gave a2ensite and I got:
Your choices are: 000-default default-ssl
Which site(s) do you want to enable (wildcards ok)?
And /etc/apache2/sites-available/default-ssl.conf:
<IfModule mod_ssl.c>
<VirtualHost _default_:443>
DocumentRoot /var/www/html
# error, crit, alert, emerg.
# modules, e.g.
#LogLevel info ssl:warn
# SSL Engine Switch:
# Enable/Disable SSL for this virtual host.
SSLEngine on
# A self-signed (snakeoil) certificate can be created by installing
# the ssl-cert package. See
# /usr/share/doc/apache2/README.Debian.gz for more info.
# If both key and certificate are stored in the same file, only the
# SSLCertificateFile directive is needed.
SSLCertificateFile /etc/ssl/certs/ssl-cert-snakeoil.pem
SSLCertificateKeyFile /etc/ssl/private/ssl-cert-snakeoil.key
# Server Certificate Chain:
# Point SSLCertificateChainFile at a file containing the
# concatenation of PEM encoded CA certificates which form the
# certificate chain for the server certificate. Alternatively
# the referenced file can be the same as SSLCertificateFile
# when the CA certificates are directly appended to the server
# certificate for convinience.
#SSLCertificateChainFile /etc/apache2/ssl.crt/server-ca.crt
# Certificate Authority (CA):
# Set the CA certificate verification path where to find CA
# certificates for client authentication or alternatively one
# huge file containing all of them (file must be PEM encoded)
# Note: Inside SSLCACertificatePath you need hash symlinks
# to point to the certificate files. Use the provided
# Makefile to update the hash symlinks after changes.
#SSLCACertificatePath /etc/ssl/certs/
#SSLCACertificateFile /etc/apache2/ssl.crt/ca-bundle.crt
# Certificate Revocation Lists (CRL):
# Set the CA revocation path where to find CA CRLs for client
# authentication or alternatively one huge file containing all
# of them (file must be PEM encoded)
# Note: Inside SSLCARevocationPath you need hash symlinks
#SSLCARevocationPath /etc/apache2/ssl.crl/
#SSLCARevocationFile /etc/apache2/ssl.crl/ca-bundle.crl
# Client Authentication (Type):
# Client certificate verification type and depth. Types are
# none, optional, require and optional_no_ca. Depth is a
# number which specifies how deeply to verify the certificate
# issuer chain before deciding the certificate is not valid.
#SSLVerifyClient require
#SSLVerifyDepth 10
# SSL Engine Options:
# Set various options for the SSL engine.
# o FakeBasicAuth:
# Translate the client X.509 into a Basic Authorisation. This means that
# the standard Auth/DBMAuth methods can be used for access control. The
# user name is the `one line' version of the client's X.509 certificate.
# Note that no password is obtained from the user. Every entry in the user
# file needs this password: `xxj31ZMTZzkVA'.
# o ExportCertData:
# This exports two additional environment variables: SSL_CLIENT_CERT and
# SSL_SERVER_CERT. These contain the PEM-encoded certificates of the
# server (always existing) and the client (only existing when client
# authentication is used). This can be used to import the certificates
# into CGI scripts.
# o StdEnvVars:
# This exports the standard SSL/TLS related `SSL_*' environment variables.
# Per default this exportation is switched off for performance reasons,
# because the extraction step is an expensive operation and is usually
# useless for serving static content. So one usually enables the
# exportation for CGI and SSI requests only.
# o OptRenegotiate:
# This enables optimized SSL connection renegotiation handling when SSL
# directives are used in per-directory context.
#SSLOptions +FakeBasicAuth +ExportCertData +StrictRequire
<FilesMatch "\.(cgi|shtml|phtml|php)$">
SSLOptions +StdEnvVars
</FilesMatch>
<Directory /usr/lib/cgi-bin>
</Directory>
# SSL Protocol Adjustments:
# The safe and default but still SSL/TLS standard compliant shutdown
# approach is that mod_ssl sends the close notify alert but doesn't wait for
# the close notify alert from client. When you need a different shutdown
# approach you can use one of the following variables:
# o ssl-unclean-shutdown:
# This forces an unclean shutdown when the connection is closed, i.e. no
# SSL close notify alert is send or allowed to received. This violates
# the SSL/TLS standard but is needed for some brain-dead browsers. Use
# this when you receive I/O errors because of the standard approach where
# mod_ssl sends the close notify alert.
# o ssl-accurate-shutdown:
# This forces an accurate shutdown when the connection is closed, i.e. a
# SSL close notify alert is send and mod_ssl waits for the close notify
# alert of the client. This is 100% SSL/TLS standard compliant, but in
# practice often causes hanging connections with brain-dead browsers. Use
# this only for browsers where you know that their SSL implementation
# works correctly.
# Notice: Most problems of broken clients are also related to the HTTP
# keep-alive facility, so you usually additionally want to disable
# keep-alive for those clients, too. Use variable "nokeepalive" for this.
# Similarly, one has to force some clients to use HTTP/1.0 to workaround
# their broken HTTP/1.1 implementation. Use variables "downgrade-1.0" and
# "force-response-1.0" for this.
# BrowserMatch "MSIE [2-6]" \
# nokeepalive ssl-unclean-shutdown \
# downgrade-1.0 force-response-1.0
</VirtualHost>
</IfModule>
EDIT:
Couldn’t I somehow use this conf?
By using the --post-hook "service httpd reload", right?
EDIT:
sudo certbot certonly -d leptokaropoulos.gr -d www.leptokaropoulos.gr --authenticator webroot -w /var/www/html/ --post-hook "service httpd reload"
That config does use the same root, so it would show the same content.
But it (and the other one) bypasses varnish, so it should be modified before put into production use.
By using the certonly parameter.
We will get to installing/using the cert and then setup the renewals with the auto service restart.
Ok got it, so:
Mind asking you, how to set the renewal?
Thank you very much for your time and help @rg305 (and @_az)!
EDIT:
I was following this tutorial.
Get the cert first.
The rest is easy.
That tutorial doesn’t fit your varnished site.
