I had an issue with my home server, had to wipe a drive and the SSL certificates were involved, I used nginx proxy manager to request the SSL certificates before and since the wipe, I have not been able to re-request these, I've redeployed NGINX as it was dropped, so this would be a fresh install, I don't know if I needed some keys from before or not, but I do not have access to any previous SSL/Cert files.
by the way, the output of the command below says there is a file created for the logs, but there isn't any.
Also, sorry if this is a repeated question (probably is) I've read FAQs and some threads around and I haven't been able to find a solution.
My domain is: lakakid.dev
I ran this command: through NGINX proxy manager:
certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-5" --agree-tos --authenticator webroot --email "lakakidd@gmail.com" --preferred-challenges "dns,http" --domains "jellyfin.lakakid.dev"
[11/3/2023] [7:03:46 AM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/proxy_host/2.conf
info Reloading Nginx
[11/3/2023] [7:03:59 AM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/proxy_host/2.conf
[11/3/2023] [7:03:59 AM] [Nginx ] › ⬤ debug Could not delete file: {
"errno": -2,
"syscall": "unlink",
"code": "ENOENT",
"path": "/data/nginx/proxy_host/2.conf"
[11/3/2023] [7:03:59 AM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/proxy_host/2.conf.err
"errno": -2,
"code": "ENOENT",
"path": "/data/nginx/proxy_host/2.conf.err"
[11/3/2023] [7:04:04 AM] [SSL ] ›
info Requesting Let'sEncrypt certificates for Cert #5: jellyfin.lakakid.dev
info Command: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-5" --agree-tos --authenticator webroot --email "lakakidd@gmail.com" --preferred-challenges "dns,http" --domains "jellyfin.lakakid.dev"
[11/3/2023] [7:04:07 AM] [Nginx ] › ⬤ debug Deleting file: /data/nginx/temp/letsencrypt_5.conf
[11/3/2023] [7:04:07 AM] [Express ] ›
warning Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-5" --agree-tos --authenticator webroot --email "lakakidd@gmail.com" --preferred-challenges "dns,http" --domains "jellyfin.lakakid.dev"
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.
My web server is (include version): nginx version: openresty/1.21.4.2
The operating system my web server runs on is (include version): Ubuntu 22.04.2 LTS x86_64
My hosting provider, if applicable, is: N/A / self-hosted
No, ubuntu server CLI
