that’s not a DNS problem, there is an answer. Please share your certbot command you have used (not the installation command, the certificate creation command).
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1. Set the ‘ServerName’ directive globally to suppress this message
VirtualHost configuration:
*:80 is a NameVirtualHost
default server poultrypages.com (/etc/apache2/sites-enabled/000-default.conf:4)
port 80 namevhost poultrypages.com (/etc/apache2/sites-enabled/000-default.conf:4)
alias www.poultrypages.com
port 80 namevhost poultrypages.com (/etc/apache2/sites-enabled/poultrypages.com.conf:1)
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“www-data” id=33
Group: name=“www-data” id=33
