Ssl is not connecting
itflow.swlabservices.com
nginx
ubuntu 22.04
That domain no longer resolves to an IP address.
And, your error message says you used the Apache authenticator but you describe using an nginx server.
Can you explain in more detail what you are trying to do? Thanks
The IP address in the error message belongs to CloudFlare.
The "502" in the error message implies that CF wasn't able to reach your [originating] web service.
If you are going to use CF, you should just take advantage of their "integrated certificates".
the website will not display until it has an SSL.
i can get the local part to work for a little bit tell i am done setting it up.
i can't log in tell i get an SSL attached to the website.
but it keeps erroring out.
can you explain the integrated certificates more so i can see if i have that in place.
https://raw.githubusercontent.com/itflow-org/itflow-install-script/main/itflow_install.sh
Sorry, I don't use Cloudlfare :frowning:
