fluxed.xyz
well i was trying to use cert bot, it didnt work
and the first result was this website.
i hoping someone could at least point me in the right direction
And what were you trying to achieve using certbot? Because your thread title says "My domain won't connect to most things".. Which is kinda vague and probably not related to Let's Encrypt and/or TLS certificates. But certbot is.. So could you please explain, from the beginning, step by step what you're trying to achieve EXACTLY and what you already tried IN DETAILS? "trying to use certbot" does not give us much to work with.. Frankly, almost nothing to work with.
Also, please answer all the questions from the questionnaire in the first post. Those are ALL mandatory, not just the domain name. If you don't know the answer to a question, please answer that, but don't leave anything empty.
If you require help there actually is a minimum amount of effor you need to put into it. You need to help us help you. Thank you for understanding.
yea sorry
umm pterodactyl is a Minecraft back-end page that helps me with my servers
um thanks for your help but imma try else where
and sorry being so vague
