Still having let's encrypt problems
ingber.com
certbot
www.ingber.com
Linode
Yes
No
certbot 3.1.0
What was the rest of the output?
No, it isn't. Please answer correctly.
You can log into a root shell, but don't know what OS you're running?
There's no obvious reason for this to fail, but you've given us almost no information to work with.
I note that www.ingber.com is serving a certificate for blog.ingber.com that expired over two months ago.
Hi @lingber,
Here is what I see using curl
$ curl -Ii http://www.ingber.com/.well-known/acme-challenge/sometestfile -A "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
HTTP/1.1 302 Found
Date: Tue, 04 Feb 2025 19:04:09 GMT
Server: Apache/2.4.58 (Ubuntu)
Location: https://www.ingber.com/.well-known/acme-challenge/sometestfile
And following the redirection
$ curl -k -Ii https://www.ingber.com/.well-known/acme-challenge/sometestfile -A "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
HTTP/1.1 404 Not Found
Date: Tue, 04 Feb 2025 19:04:12 GMT
I would guess the the web server is Apache/2.4.58
and the Operating System is Ubuntu
These 7 domain names are severing this certificate crt.sh | 14322877690, yet from this list of issued certificates crt.sh | ingber.com there are other subdomains with newer issued certificates
  1. https://decoder.link/sslchecker/ingber.com/443
  2. https://decoder.link/sslchecker/www.ingber.com/443
  3. https://decoder.link/sslchecker/blog.ingber.com/443
  4. https://decoder.link/sslchecker/lin.ingber.com/443
  5. https://decoder.link/sslchecker/lester.ingber.com/443
  6. https://decoder.link/sslchecker/default.ingber.com/443
  7. https://decoder.link/sslchecker/lin6.ingber.com/443
Please show the output of both of these command sudo certbot certificates and sudo apachectl -t -D DUMP_VHOSTS.
