Help using Letsencrypt with ingber.com
Continuing the discussion from About the Help category:
My domain is: ingber.com
certbot -d ingber.com -d www.ingber.com
apache2 version 4.0.0
apache2 4.0.0
My hosting provider, if applicable, is: Linode
No
certbot 4.0.0
Note: I have used this command to certbot previously.
your server sends http payload directly on port 443, without TLS layer
dig apache config and set SSLEngine on there
Your site --- http://ingber.com` is serving content over HTTP that includes hundreds of links and assets pointing to https:// — but it does not redirect HTTP to HTTPS.
Create a redirect:
<VirtualHost *:80>
ServerName ingber.com
ServerAlias www.ingber.com
Redirect permanent / https://www.ingber.com/
And add HSTS in your HTTPS block:
Header always set Strict-Transport-Security "max-age=63072000; includeSubDomains; preload"
In addition:
Your server at ingber.com is listening on port 443, which tells browsers and tools to expect a secure HTTPS connection.
But it responds with unencrypted HTTP.
This breaks TLS handshakes and triggers errors like “wrong version number” in curl and SSL scan tools.
It’s misleading and non-compliant with HTTPS expectations, and the correct fix is to serve proper TLS on port 443 or close it entirely if you don’t intend to support HTTPS.
This is an invalid apache vhost configuration and outside the scope of this forum.
My 2 cents. ;@)
Where's the output?
That's not a valid Apache version.
Apache is not an operating system.
