Set up cert for Cloudflare for Strict SSL?
Ubuntu 18
Linode
Yes
No
certbot 0.31.0
The problem is that I have to set up Cloudflare properly to avoid uninterrupted service since I have been running Full Strict SSL for some years.
What's your exact question or issue? Because I'm currently not seeing one.
Well, my letsencrypt won't update, but since I'm not sure if the letsencrypt.log file contains secure info, I won't post that here.
Without knowing anything about what you did and what the output was, we can't help you. You didn't specify the command you ran and no output at all.
I ran
/usr/bin/letsencrypt renew >& /var/tmp/cron.letsenc
and that file shows
Processing /etc/letsencrypt/renewal/www.ingber.com.conf
http-01 challenge for blog.ingber.com
http-01 challenge for default.ingber.com
http-01 challenge for ingber.com
http-01 challenge for lester.ingber.com
http-01 challenge for lin.ingber.com
http-01 challenge for lin6.ingber.com
http-01 challenge for www.ingber.com
Attempting to renew cert (www.ingber.com) from /etc/letsencrypt/renewal/www.ingb
er.com.conf produced an unexpected error: Missing command line flag or config en
try for this setting:
Input the webroot for blog.ingber.com:. Skipping.
/etc/letsencrypt/live/www.ingber.com/fullchain.pem (failure)
In /var/log/letsencrypt/letsencrypt.log I see at the end:
2020-09-23 11:59:18,381:ERROR:certbot.renewal:All renewal attempts failed. The f
ollowing certs could not be renewed:
2020-09-23 11:59:18,381:ERROR:certbot.renewal: /etc/letsencrypt/live/www.ingber
2020-09-23 11:59:18,382:DEBUG:certbot.log:Exiting abnormally:
File "/usr/bin/letsencrypt", line 11, in
load_entry_point('certbot==0.31.0', 'console_scripts', 'certbot')()
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1365, in main
File "/usr/lib/python3/dist-packages/certbot/main.py", line 1272, in renew
renewal.handle_renewal_request(config)
File "/usr/lib/python3/dist-packages/certbot/renewal.py", line 477, in handle_
renewal_request
len(renew_failures), len(parse_failures)))
certbot.errors.Error: 1 renew failure(s), 0 parse failure(s)
It seems your renewal configuration file is damaged for some reason. It's missing critical information: the webroot. Did you manually edit the file by any chance?
No, I did not. I thought perhaps a python3 update messed up, but I did a search and do not see this problem cited. So, what should I do now?
You could manually add the webroot again to the renewal configuration file (look in other renewal configuration files for examples if you have them).
You could also try to issue the certificate again. I.e., run certbot again without renew. It should store all the parameters again in the renewal configuration file after that. If you have more than one certificate in certbot, you can identify the certificate name from the list generated by certbot certificates. After that, you could use certbot --cert-name <insert cert name here> with after that the required options to issue a certificate like you did in the beginning.
OK. I'll try that. Thanks for your time and the suggestion.
He could also specify the entire command with the webroot and certbot should update the configuration automatically. That is unless certbot is barred from doing so for some reason. He could then use /usr/bin/letsencrypt certificates as you've suggested to note the old certificate name(s) then use /usr/bin/letsencrypt delete *old certificate name* to cleanup.
This would imply running the following:
/usr/bin/letsencrypt certonly --cert-name ingber.com -a webroot -w *put the webroot here* -d ingber.com,www.ingber.com,blog.ingber.com,default.ingber.com,lester.ingber.com,lin.ingber.com,lin6.ingber.com
edit:
This is what @Osiris was meaning here:
Didn't realize I was duplicating. Sorry @Osiris. Hopefully the command and cleanup add value though.
That's what I said in my second paragraph, right?
You are going to somewhat hate my response, but you went through all these headaches for no reason.
Cloudflare is handling the "internet facing" SSL for all your domains (from a web browser to their Edge servers); if you click on the padlock for any of your sites in a browser window, you'll see their Certificates, not LetsEncrypt.
The LetsEncrypt certificates you obtained are only being used to Encrypt traffic between your web server (origin) and Cloudflare's network. While you can use LetsEncrypt to obtain these, they need to be renewed at least every 3 months.
The alternative? Cloudflare offers their own "Origin SSL Certificates" (https://support.cloudflare.com/hc/en-us/articles/115000479507) which you can just download and install onto your server. These certificates last 15 years.
The two main problems with running LetsEncrypt certificates behind Cloudflare:
  1. The http/https traffic used to validate the certificates is proxied through Cloudflare, so you can sometimes have hiccups of configuration issues within the Cloudflare network that you have no control over
  2. There are sometimes oddities troubleshooting/bugfixing that get complicated by this setup because public DNS no longer resolves to your website but resolves to the Cloudflare network
Which is also important?
Did you not read the next paragraph or was it unclear the alternative certificate from cloudflare, which you simply download once every 15 years, encrypts that segment?
