Cloudflare renewal problem
My domain is: kborowy.pl
I ran this command: renew dry run
Attempting to renew cert (kborowy.pl) from /etc/letsencrypt/renewal/kborowy.pl.conf produced an unexpected error: Missing command line flag or config entry for this setting:
Input the webroot for kborowy.pl:. Skipping.
My web server is (include version): apache 2.4 as i remember
The operating system my web server runs on is (include version):centos 7
I can login to a root shell on my machine (yes or no, or I don't know): y
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):1.7.0
What can be done to make it working via cloudflare?
Try this to test:
sudo certbot certonly --webroot -w /var/www/html -d "kborowy.pl,www.kborowy.pl" --dry-run
If that succeeds, run this:
sudo certbot run --webroot -w /var/www/html -d "kborowy.pl,www.kborowy.pl" --deploy-hook "sudo apachectl -k graceful"
You should consider using a Cloudflare Origin CA certificate rather than a Let's Encrypt certificate. They last much longer and are easier to manage via Cloudflare.
Hi griffin, thanks for response.
Nothing from certbot commands work.
Please, cause i see not really clear this cloudflare pages. When i got letsencrypt cert and use it via cloudflare i should see (with strict full encryption) letsenrcypt cert when checking green padlock info.
What should i see when i am using cloudflare origin cert? Cause now i see one year cert, not 15 y one. Is it ok?
Check my webpage please and let me know.
On CL pages i see green medal on origin server and 2 green padlocks. How can i verify if it is all working fine?
You will never see a Let's Encrypt certificate through Cloudflare when checking the padlock unless you have a premium Cloudflare plan and upload your own certificate. If you visit the "end-to-end" link I gave you, you'll see why. A Let's Encrypt certificate only covers between Cloudflare and your server. That's also what a Cloudflare Origin CA certificate covers. The certificate you see in the image below is the Cloudflare certificate that covers between your visitors and Cloudflare. It's the only certificate that you (or your visitors) will ever see.
Exhibit A:
Are You sure You need premium plan?
Is there any way to check webpage plan (webpage which is not mine) ?
Absolutely.
https://support.cloudflare.com/hc/en-us/articles/203295200
I assume you would only know specifically by looking at the Cloudflare account. You could infer the plan type based on the usage of more advanced features (like Custom SSL).
Only if you require a Let's Encrypt visible to the users webbrowser. Note that CloudFlare certificates are trusted and secure too..
