Tesfay
February 14, 2020, 11:32am
1
I have followed the Certbot instruction for my ubuntu server, and the steps successfully finished as expected. However, after I tried to access the website using HTTPS it did not work, but it is working using HTTP as usual. Any suggestion?
My domain is: fetlee.allenatech.com
I ran this command: sudo certbot --nginx
It produced this output: Which names would you like to activate HTTPS for?
My web server is: nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is: Ubuntu 18.04.4 LTS (Bionic)
I can login to a root shell on my machine: Yes
The version of my client is (e.g. output of ‘certbot --version’ or certbot-auto --version if you’re using Certbot): certbot 0.31.0
danb35
February 14, 2020, 11:48am
2
Tesfay:
Any suggestion?
You could try answering the questions you deleted when you started this topic. Without that information, none of us has any basis to guess what might be happening.
Tesfay
February 14, 2020, 12:15pm
3
Thank you for the feedback, I have edited the post.
Hi @Tesfay
there is a check of your domain, ~~5,5 hours old - https://check-your-website.server-daten.de/?q=fetlee.allenatech.com
You have created two certificates, so that part has worked.
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
Let's Encrypt Authority X3
2020-02-14
2020-05-14
fetlee.allenatech.com - 1 entries
duplicate nr. 2
2020-02-14
2020-05-14
duplicate nr. 1
But your https doesn't work.
Works https internal?
curl https://fetlee.allenatech.com/
from that server?
What says
nginx -T
certbot certificates
Tesfay
February 14, 2020, 2:56pm
5
Hi @JuergenAuer ,
Here are the commands with their results:
Command 1: curl https://fetlee.allenatech.com/
Result 1: curl: (7) Failed to connect to fetlee.allenatech.com port 443: Connection refused
Command 2: certbot certificates
Result 2:
Found the following certs:
Certificate Name: fetlee.allenatech.com
Domains: fetlee.allenatech.com
Expiry Date: 2020-05-14 07:48:27+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/fetlee.allenatech.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/fetlee.allenatech.com/privkey.pem
Moreover, now, both HTTP and HTTPS are not working.
Tesfay
February 17, 2020, 1:27pm
6
Solved! The issue was docker related.
