Hello,
I am using unbuntu 18 and using nginx reverse proxy for a domain . please advise if anything is missed here. It used to work fine until 13th, suddenlty today it stopped working. No changes on nginx or certbot
checks:
1)Certbot installed ok.
2) Nginx seems fine.
3) We are running this on aws lightsail, where i enabled port 80,443, 22
4) domain dns mapping is ok also in our domain provider
error: When i use my domain https://domain, it says. 404 Not Found . nginx/1.14.0 (Ubuntu)
details: Nginx file is here..
server_name ;
root /home/ubuntu/haix-alivecore-v2/dist;
index index.html index.htm;
try_files $uri /index.html =404;
proxy_read_timeout 3600;
proxy_connect_timeout 3600;
proxy_send_timeout 3600;
ssl_protocols TLSv1.2;
ssl_certificate /etc/letsencrypt/live//fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live//privkey.pem; # managed by Certbot
if ($host = ) {
} # managed by Certbot
server_name ;
listen 80;
or certbot-auto --version
if you're using Certbot):
