Your certificate works correct with brandculture.africa, this is your certificate name.
But you have a redirect non-www -> www, your certificate doesn't have the www-entry.
So this is a mismatch.
Version 1: Remove the redirect (not good)
Version 2: Create a new certificate with -d brandculture.africa -d www.brandculture.africa, so you have one certificate with two domain names (better).
So visitors can use your site by typing non-www + www.
