SSL succesfully installed but it show not secure and expiry in 81 days
My domain is: mykidmall.com
I ran this command: not sure, i am beginner of web design
It produced this output: not sure, i am beginner of web design
My web server is (include version): not sure, i am beginner of web design
The operating system my web server runs on is (include version): not sure, i am beginner of web design
My hosting provider, if applicable, is: hostgator
I can login to a root shell on my machine (yes or no, or I don’t know): yes, i can login to Cpanel
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): CPANEL 78.0.30
Hi @ahyaw84
checking your domain - https://check-your-website.server-daten.de/?q=mykidmall.com#ct-logs
You have two different certificates:
Sectigo RSA Domain Validation Secure Server CA 2019-06-30 2020-06-29 www.boonyaw.com, www.mykidmall.com - 2 entries
Let's Encrypt Authority X3 2019-06-21 2019-09-19 autodiscover.mykidmall.com, cpanel.mykidmall.com, mail.mykidmall.com, mykidmall.boonyaw.com, mykidmall.com, webdisk.mykidmall.com, webmail.mykidmall.com, www.mykidmall.boonyaw.com, www.mykidmall.com - 9 entries
Let's Encrypt Authority X3 2019-04-21 2019-07-20 autodiscover.mykidmall.com, cpanel.mykidmall.com, mail.mykidmall.com, mykidmall.boonyaw.com, mykidmall.com, webdisk.mykidmall.com, webmail.mykidmall.com, www.mykidmall.boonyaw.com, www.mykidmall.com - 9 entries
The Letsencrypt certificate is created from your cPanel and has all domain names. The newer Sectigo certificate is wrong, mykidmall.com is missing. So you shouldn't use that certificate.
And both connections are secure:
http://www.mykidmall.com/
216.172.184.196 301 http://mykidmall.com/ 0.857 D
216.172.184.196 200 2.567 H
https://www.mykidmall.com/
216.172.184.196 301 https://mykidmall.com/ 1.750 B
216.172.184.196 200 3.330 I
But you don't have a redirect http + non-www -> https + non-www. So if you use the non-www version with http, you are insecure.
And you have one mixed content problem:
https://mykidmall.com/wp-content/uploads/elementor/css/post-9.css?ver=1561926760
loads three urls via http:
http://mykidmall.com/wp-content/uploads/2019/05/people-2599980_960_720-1.jpg
1
http://mykidmall.com/wp-content/uploads/2019/06/baby-clothing.jpg
1
http://mykidmall.com/wp-content/uploads/2019/06/pexels-photo-266023.jpeg
1
That's the mixed content warning in your browser.
But this warning is mixed content, not a wrong certificate. So fix these links.
The “expiry in 81 days” part is perfectly normal; certificates from Let’s Encrypt are good for 90 days. If the Cpanel integration is working as it should be, the certificate is automatically renewed before it expires (usually about a month before it expires).
Dear JuergenAuer,
Thanks for reply and your professional support. May i know what should i do next to solve this issue? I am a layman on this SSL.
Should i purchase another SSL certificate or is there other way to re-do the SSL?
I need your professional advise.
Thanks again.
Regards,
Boon Yaw
Your SSL works, there is no problem. The cPanel Letsencrypt certificate is up to date. You don't need another certificate.
Fix the mixed content problem https://check-your-website.server-daten.de/?q=mykidmall.com#html-content reports. You have a Grade I, that's not good.
If you have fixed that, you may have a Grade H (http without redirect https).
216.172.184.196 301 http://mykidmall.com/ 0.816 D
216.172.184.196 200 2.017 H
216.172.184.196 301 https://mykidmall.com/ 1.857 B
216.172.184.196 200 2.983 I
Your http + non-www needs a redirect to https. So add one.
