Ssl for centos 6 apache 2.2.15
Dear Experts
can any one clear me that
is lets encrypt also support centos version 6 with apache 2.2.15
webserver
for ssl certificate
kindly help me out
Neeraj Sharma
Let’s Encrypt supports any OS and web server that can use PEM-encoded x.509 server certificates, which certainly includes CentOS 6. I wouldn’t recommend using the certbot client with CentOS 6, though. Instead, try one that’s simpler and has fewer dependencies, like acme.sh. See:
Hi @neeraj
it's not the question if Letsencrypt supports that OS.
It's the question if there is a Letsencrypt client you can use with that OS. It's always possible to write an own client. But that may not be the best option.
Start with some basics:
Then select a client.
Checking Certbot there is a CentOS 6 support. But there are a lot of other clients.
