SSL connection failed for acme-v02.api.letsencrypt.org
SSL connection failed for acme-v02.api.letsencrypt.org: SSL connect attempt failed error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed on generate SSL.
Its my curl response:
> curl -v https://acme-v02.api.letsencrypt.org/directory
> % Total % Received % Xferd Average Speed Time Time Time Current
> Dload Upload Total Spent Left Speed
> 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 172.65.32.248:443...
* Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: D:/Program Files/Git/mingw64/ssl/certs/ca-bundle.crt
CApath: none
} [5 bytes data]
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* TLSv1.3 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
{ [19 bytes data]
* TLSv1.3 (IN), TLS handshake, Certificate (11):
{ [3025 bytes data]
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
{ [264 bytes data]
* TLSv1.3 (IN), TLS handshake, Finished (20):
{ [52 bytes data]
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
} [1 bytes data]
* TLSv1.3 (OUT), TLS handshake, Finished (20):
} [52 bytes data]
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use h2
* Server certificate:
* subject: CN=acme-v01.api.letsencrypt.org
* start date: Oct 18 20:04:26 2021 GMT
* expire date: Jan 16 20:04:25 2022 GMT
* subjectAltName: host "acme-v02.api.letsencrypt.org" matched cert's "acme-v02.api.letsencrypt.org"
* issuer: C=US; O=Let's Encrypt; CN=R3
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
} [5 bytes data]
* Using Stream ID: 1 (easy handle 0x950360)
} [5 bytes data]
> GET /directory HTTP/2
> Host: acme-v02.api.letsencrypt.org
> user-agent: curl/7.71.1
> accept: */*
{ [5 bytes data]
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
{ [57 bytes data]
{ [57 bytes data]
* old SSL session ID is stale, removing
{ [5 bytes data]
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
} [5 bytes data]
< HTTP/2 200
< server: nginx
< date: Thu, 21 Oct 2021 06:22:58 GMT
< content-type: application/json
< content-length: 658
< cache-control: public, max-age=0, no-cache
< x-frame-options: DENY
< strict-transport-security: max-age=604800
{ [658 bytes data]
100 658 100 658 0 0 3500 0 --:--:-- --:--:-- --:--:-- 3655{
"W0X5metR8HE": "https://community.letsencrypt.org/t/adding-random-entries-to-the-directory/33417",
"meta": {
"caaIdentities": [
"letsencrypt.org"
"termsOfService": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf",
"website": "[https://letsencrypt.org](https://letsencrypt.org/)"
* Connection #0 to host acme-v02.api.letsencrypt.org left intact
any way to fix this error?
The ACME client is failing, however the test with curl seems to be OK. What is your ACME client and what is its version?
Hello, @bruncsak
can you please guide how can I check the ACME client and version.
You executed some command, when you got the original error message. What command did you execute?
I did this command execute : dotnet AzureLetsEncrypt.dll
I use AzureLetsEncrypt version 1.1.
Is that the latest (or a recent) version?
If it is this one:
[you can see that it's now up tp version 1.4.0]
Also: That seems to rely on LE64.exe which needs to be at v0.38 [or newer]
They need to maintain that program!
The "embedded" LE64.exe is very outdated:
[ ZeroSSL Crypt::LE client v0.34 started. ]
Get the latest LE64 from that source (directly):
I speak as a user of LE64:
Thanks @rg305
Certificate was generated after I replaced the le64 file.
