SSL certificates on Synology behind double firewall
My domain is: www.pasithea.be
  • Tried Synology certificate but doesn't work behind double firewall (and no, I can not get rid of that, sorry, would make my life much easier too ) with double port fwd
  • Tried installing certbot but can't find synology as device OS.... any alternative ?
  • Tried playing with acme.sh but my domain provider is not listed and I am not skilled enough to program it myself.
My web server is (include version): apache 2.4
The operating system my web server runs on is (include version): Synology DSM 6
My hosting provider, if applicable, is: level27.be voor DNS records, I host my website on my home synology nas
I can login to a root shell on my machine (yes or no, or I don't know): absolutely
Euh, yeah, the one provided by level27.be I suppose ?
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): failed to install for now on my synology
Would appreciate some help. I tried configuring my synology in the internet facing firewall but they are not in the same domain so my ISP router (Technicolor) doesn't accept it . So I put my 2nd firewall, but that port 80 points to its own management web page.
Please help. Tx in advance.
Kris
Welcome Back to the Let's Encrypt Community, Kris :slightly_smiling_face:
Have you considered just using a dns-01 challenge (instead of the http-01 challenge you are trying to use) to prove control of the domain name that your NAS uses?
Synology NAS have a built-in menu choice to get an LE cert:
Control Panel | Security | Certificate
The typical problem is that Synology runs HTTP on port 5000 and HTTPS on 5001.
So one of your NATs may have to accommodate 80 > 5000 to validate via HTTP.
OR
You could hack the web server config and add:
Listen 80
[ I also have multiple firewalls :slight_smile: ]
