Ssl certificate not valid
My domain is: www.tuitiontitan.my
I ran this command: Tried to access my website
"Your connection is not private
Attackers might be trying to steal your information from www.tuitiontitan.my (for example, passwords, messages or credit cards). Learn more.
NET::ERR_CERT_COMMON_NAME_INVALID
My hosting provider, if applicable, is: wyglobe yegon
I can login to a root shell on my machine (yes or no, or I don’t know): i don’t know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): wypanel
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): not using
You need to activate the Let’s Encrypt certificate from your hosting provider’s control panel.
If like your current situation, your certificate is not active, please contact your hosting provider for assistance.
Thank you
Hi, thanks for the fast reply.
The status shown is active the Lets Encrypt SSL on my control panel. Does this means its activated?
The certificate is issued to your domain. It’s issued but not installed. You need to contact your hosting provider and ask them to help you configure it. (From the manual, it’s supposed to activate / install automatically)
