SSL Certificate not applying
Unable to complete challenge with Lets Encrypt servers error was: {“type”:“http-01”,“url”:“https://acme-v02.api.letsencrypt.org/acme/chall-v3/4641020508/hq7YWA",“status”:“Invalid”,“validated”:null,“error”:{“Type”:“urn:ietf:params:acme:error:unauthorized”,“Detail”:"Invalid response from https://stargems.co.nz/cpanel_account_suspended.html [2404:8280:a222:bbbb:bba1:10:ffff:ffff]: “\n \n Account Suspended\n \n <body leftmargin=\“0\” topmargin=\“0\” style=\“margin:0;\”>\n <ifra””,“Identifier”:null,“Subproblems”:null,“Status”:403},“errors”:null,“token”:“m7ZPCxVLweOfEGt8h7tgwqwTcOts8QIORcr7al6hyXw”,“keyAuthorization”:null}
My domain is: Stargems.co.nz
I ran this command: I am using Azure LetsEncrypt Extension
The operating system my web server runs on is (include version): Window (Azure hosting)
My hosting provider, if applicable, is: Azure
I am login from My Azure portal.
Hi @tali200x
read your error message.
Looks like your cPanel account isn’t active.
Thank for reply
My client got this domain from other party. I have mapped his domain with our stargems.azurewebsites.net.
So this error is coming form domain registration provider or its something from my side.?
That’s what the DNS records are set to.
stargems.co.nz.  14400  A     40.76.218.33
stargems.co.nz.  14400  AAAA  2404:8280:a222:bbbb:bba1:10:ffff:ffff
The IPv4 address is assigned to Azure; the IPv6 address is assigned to Dreamscape Networks.
If you’re not using Dreamscape Networks, you should get rid of the AAAA record.
(And get IPv6 support on Azure!)
