thanks alot sir
i have been working on this since 2 weeks
thanksalot for your time and help
sir i have a problem again
if i use the domain https://jobsforops it is working
but if i use ip address it is still unsecure 35.80.193.124
please check it once
Your certificate is not valid for the IP address and Let's Encrypt does not issue certificates for IP addresses. Please don't use the IP address.
@srikanth There is nothing wrong with your chain. You are serving the same fullchain that this website serves. That said, there are tradeoffs between choosing the short or long chain. Below is an intro topic on that although I am afraid it might be too technical for you:
I suggest using this tool to evaluate your site. I do not recognize the one you used - which was it? The one below is very popular and shows more clearly what your chain looks like:
https://www.ssllabs.com/ssltest/analyze.html?d=jobsforops.com&hideResults=on
As a test, try the tool with your site and this website and compare results.
I am sorry I had to leave earlier but very glad Rudy was able to get you sorted.
@srikanth I also just saw this thread that might better explain the difference between the short and long chains to you. Still, you can take comfort that this website (and many others) are using the long chain like you.
