certbot certificates
Found the following certs:
Certificate Name: www.jobsforops.com
Serial Number: 431268f3abc75e0a33ec4c5c0e1a7ac0525
Key Type: RSA
Domains: www.jobsforops.com
Expiry Date: 2022-01-05 09:16:18+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/www.jobsforops.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.jobsforops.com/privkey.pem
rg305
23
There is the problem:
You have no cert to cover the name "jobsforops.com".
how should i resolve it sir
please provide me the solution
rg305
25
You need to redo the step that you did to get the cert you have now.
But include both names on the new request.
but i have just used this command to renew sir ,i didnot include any domains in the command
sudo certbot renew --no-self-upgrade
rg305
27
Not "renew
You need to get a new cert - with two names on it.
Do you recall how you got the cert you have now?
no sir
it was done by previous employee
but he was left now
rg305
29
Try:
history | grep certbot | grep -i jobsforops.com
rg305
32
Then we will have to guess.
Please show the files:
/etc/httpd/conf/httpd.conf
/etc/httpd/conf.d/vhost.conf
And my apology for not noticing it sooner.
There is a name:port
overlap conflict in your config:
[two separate files are using the same name on the same port]
1.txt (12.0 KB)
2.txt (1.7 KB)
and regarding this port conflict pls tell me the solution sir
rg305
36
To remove the port conflict: Remove the vhost section from the main config file.
[all of]
<VirtualHost *:80>
</VirtualHost>
Then update the second file as follows:
<VirtualHost *:80>
ServerName "jobsforops.com"
ServerAlias "www.jobsforops.com"
DocumentRoot "/var/www/html"
<Directory /var/www/html/>
AllowOverride All
Require all granted
</Directory>
RewriteEngine On
RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge [NC]
RewriteCond %{HTTPS} !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
</VirtualHost>
Restart Apache
Then we may be able to test with:
sudo certbot certonly --webroot -w /var/www/html -d jobsforops.com -d www.jobsforops.com --dry-run
yes sir i have repalced the text and
restarted
then run the command for dry run
and the output for dry run was successfull
what is the next step sir
rg305
39
OK now get a real cert, with:
[without --dry-run
Then show:
rg305
41
Please show:
Serial Number: 4e74c417334cf426b42da85bcfee2fb335e
Key Type: RSA
Domains: jobsforops.com www.jobsforops.com
Expiry Date: 2022-01-06 18:35:47+00:00 (VALID: 89 days)
rg305
43
Ok
Just restart Apache
and both names should work securely.
