SSL Causing Problems
My domain is: www.backwardsla.com
I ran this command: I followed this video https://www.youtube.com/watch?time_continue=263&v=2EjUauV5204&feature=emb_logo which linked to this article https://code.tutsplus.com/tutorials/using-lets-encrypt-ssl-with-your-wordpress-project--cms-22303 & I followed the steps.
It produced this output: IDK
My web server is (include version): IDK
The operating system my web server runs on is (include version): IDK
My hosting provider, if applicable, is: Digital Ocean
I can login to a root shell on my machine (yes or no, or I don’t know): Yes.
Huge caution signs show up when I try & go to the site.
What’s registered
My thought was to uninstall & reinstall, what do you guys think?
A picture paints a thousand words.. but there is no picture (showing the problem).
Words count as words, but there are no words used to describe... (the actual problem).
Other than:
So I am left to guess.
I think you may be using WWW and your cert doesn't cover the WWW name.
Hey! Thanks for reaching out.
Yes, how do I add WWW. to the name from terminal commands?
https://www.backwardsla.com/wp-content/uploads/2020/04/Screen-Shot-2020-04-12-at-1.40.59-PM.png
https://www.backwardsla.com/wp-content/uploads/2020/04/Screen-Shot-2020-04-12-at-2.44.16-PM.png
https://www.backwardsla.com/wp-content/uploads/2020/04/Screen-Shot-2020-04-12-at-2.47.54-PM.png
How do I either uninstall or amend for WWW.? Thank you so much rg305.
I don't have the time to go through the video, but I would guess that wherever you used the single domain ("backwardsla.com"), you would use both names ("backwardsla.com" and "www.backwardsla.com").
This should be able to be done right over the existing one (not 100% certain - again, I haven't watched the video)
So it won't really let me back to that step, it says it's already set up. Is there a way to delete the instal & restart?
The video references this article. https://code.tutsplus.com/tutorials/using-lets-encrypt-ssl-with-your-wordpress-project--cms-22303
You’re going to make me have to read…
What was the command you ran?
It looks like:
./letsencrypt-auto --apache -d fever.lookahead.io
That example needs to be augmented to cover your case:
./letsencrypt-auto --apache -d backwardsla.com -d www.backwardsla.com
Now I have some Archaeological “work” to get back to.
Oh yes, and Happy Easter!
You are my hero! Thank you so much. Go get them runes!
